Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy loads with coil springs. No modification required; keep the coil springs. Fits all 2009-16 RAM 1500 including Ecodiesel and 2014-16 RAM 2500! Spacers available for most 4" and 6" lift kits for RAM 1500
TLC also makes units for 02-13 RAM 2500 & 02-16 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™.
Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Old 05-03-2013, 05:24 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Default 1400 lb and TLC
1400lb wet pressure treated wood, love the TLC system, and it only had 30lb in the bags, its even a bit high in the rear, 20 would of been ample, box is full.
Old 05-03-2013, 05:39 PM
Arth's Avatar
Arth Arth is offline
Color: Deep Cherry Red Crystal Pearlcoat
Rep:2035
Nice! So what is the max PSI you can put in the bags safely??
Chrome... in moderation.
Old 05-03-2013, 05:45 PM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3934
You have sunshine there????
Old 05-03-2013, 06:13 PM
Vehicle: .
Rep:4373
Seriously I don't know the max, but typically 20-40lbs will level most loads
Lmao, your snow man is dead, haaaaaaaaaaaa
Old 05-11-2013, 01:39 PM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
100 PSI is the max recommended by Goodyear.
With TLC, you'll never get close to that.
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500 4500 5500
Level Every Load with TotalLoadControl.com
