Old 05-04-2013, 11:07 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
There's nothing wrong with the 6 speed(even though it only uses 5 normally). 10 years ago they only had 4 speeds. The 8 speed is nice I'm sure but people are really over exaggerating this.
Sean
Old 05-04-2013, 11:15 PM
Driver72 Driver72 is offline
Vehicle: 2014 Laramie CC 4x4 8spd 3.92
Color: White w/ Blk interior
Rep:69
Driver72 will become famous soon enough
I don't have an issue with the 6 speed, but I do have an issue with why it's a 6 speed but they only use 5 speeds in normal driving (the kind we do 98% of the time)?
I wondered why the EPA's figures for the gas mileage on the 6 speed auto didn't improve over the 5 speed autos?
The only reason I care about the 8 speed is the improved gas mileage and acceleration.
It's a bonus you get both from it.
Had the 6 speed been geared better so first gear was a bit lower and then 5th gear was a 1:1 and 6th was an ultra overdrive, they could of gotten
15 city / 21 hwy from the 6 speed for the 4x2's and at that point going to the 8 speed would of been trivial.
But as it stands, from what I can tell, the 8 speed is geared better for acceleration when needed, plus better for MPG when on the highway.
Those two things combined make it a compelling alternative to the so called 6 speed that doesn't really use 6 gears.
2015 Dodge Challenger Hellcat - 8spd
2014 Ram 1500 Laramie CC 4x4 with LSD and 3.92's -GONE-
2013 Ram 1500 Laramie CC 4x4 with LSD and 3.55's -GONE-
Old 05-04-2013, 11:17 PM
snrusnak's Avatar
Rep:1385
The "5 speed" (545rfe) and "6 speed" (65rfe) are the same transmission. Both have 6 forward gears and skip the 3rd gear on normal upshifts in drive. It was renamed for marketing.
The 8 speed has the exact same final gear ratio as the 545rfe/65rfe.
Sean
Old 05-04-2013, 11:18 PM
bigralphy bigralphy is offline
Vehicle: 2013 Ram Sport
Rep:39
bigralphy is on a distinguished road
I agree. I don't mind the 6 at all. I would rather have my 6 with 3.92 than an 8 with 3.21. I may get the 8 in a couple years if I can be sure what gears I have.
Old 05-04-2013, 11:23 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
I use my ERS quite often and I go through all 6 gears. It sure feels like six gears, indicates what gear I'm in, and sounds like six gears to me. I guess I am not a normal driver. I can accept that.
Old 05-04-2013, 11:29 PM
snrusnak's Avatar
Rep:1385
^yes with the 4th gen trucks if you use ERS mode you can access all 6 gears. Doesn't matter if it's the 545rfe or 65rfe either. But the 2nd and 3rd gears are so close in ratio it's not really worth it, they are nearly the same gear.
Sean
Old 05-04-2013, 11:51 PM
Gantman's Avatar
Rep:974
I do agree with how so very close in ratio, 2nd(1.67:1) and 3rd(1.50:1) are to each other. It's as close as 5th(0.75:1) is to 6th(0.67:1). You can feel the rpm drop change if you are listening closely. But I think this RFE stuff has all been covered many moons ago, soooooo, Ya'll be good.
Old 05-05-2013, 12:51 AM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:67
I actually didn't mind the 5 in the 09 after using a DS to shut down the MDS. I didn't even need the tow mode with the 3.92's. With the 3.55'a in my 13 I am stuck using it again and losing MPGs. I usually just leave it in 6th to keep the MDS off. Sure the 8spd is nice but not a huge deal to me. I will be happier when the release the DS tuning for the 13's more than anything since the 87 tune and MDS off gained me a couple MPG in my 09 hopefully it will do the same in this one. Maybe next time I will try out a 8 spd of there isn't a newer tranny by then.
Old 05-05-2013, 01:13 AM
Unfairkickazz93's Avatar
Unfairkickazz93 Unfairkickazz93 is offline
Vehicle: 2012 Dodge Ram 1500 RCSB 4X4
Rep:173
Unfairkickazz93 has a spectacular aura aboutUnfairkickazz93 has a spectacular aura about
Interesting read there. I have the 3.92s with the "6" speed so that is ggod to hear haha. How do you like the 8 speed when you start going?
MODS- QTP Exhaust Cutout, ARH Long-tube Headers, HornBlasters Train Horn, HemiFever Tuned, Linex bedliner, Painted mirrors and door handles, 14" magnaflow muffler, Cabin air filter, BakFlip G2 tonneau cover, Black 17" Sport Edition TK5 Wheels, K&N CAI, BT Catch can, 85mm Throttle body, Upper glovebox Mod, Recon Black Projector headlights, Retroshops- Tinted LED Tails including 3rd brake.
Old 05-05-2013, 02:59 AM
rraulston rraulston is offline
Vehicle: 2013 Ram Sport Crew Cab Hemi
Rep:7
rraulston is an unknown quantity at this point
Wrong.....the final drives are the same.........for those of you wishing you had an 8 speed.....don't. There is nothing wrong with 6 speed trannys. The 8 speed might (who races to 75mph?? who cares??) get to speed a few 10th of a second faster but crusing the freeway, its all the same.
