Old 11-17-2013, 08:46 PM
s34n s34n is offline
Vehicle: 2013 Dodge Ram
Rep:54
s34n will become famous soon enough
Default HID lights
So I've been trying to install HID lights on my truck and can't figure out the issue. With or without the error code eliminators they don't work. I know the ballasts work and connections are right. So I'm on the verge of giving up on the idea of HIDS.
Anyone with any ideas I'd appreciate it.
Old 11-17-2013, 09:31 PM
Arth's Avatar
Arth Arth is online now
Color: Mineral Gray Metallic
Rep:2028
When you say they don't work... are you saying no fire at all?
Two things to check. Your grounds and make sure you have the connectors facing the right way....or pinned correctly.
I know if you got the retro*solution kit that is possible.
Chrome... in moderation.
Old 11-17-2013, 09:56 PM
daviddup78's Avatar
daviddup78 daviddup78 is offline
Vehicle: 2012 Ram 1500 HEMI 4x4
Trim Level: Lone Star
Color: deep cherry red
Rep:71
daviddup78 will become famous soon enough
yes check and see if u plugged them up back wards, its possible bec they can go both ways,
do you have the quad style headlights? or do you just have one bulb as a hi/low
2012 Dodge Ram 1500 4x4 with goodies and 6'' Fabtech lift
Old 11-17-2013, 10:44 PM
bstunder bstunder is offline
Vehicle: 2013 Ram 1500 Laramie Longhorm
Trim Level: Laramie Longhorn
Color: Grey Met
bstunder is on a distinguished road
Your truck utilizes a CANBUS system for the wiring and the HID kits need to be compliant with the CANBUS system. Not all HID kits will work
Old 11-17-2013, 11:37 PM
Rep:54
@arth... Correct no firing at all.
@david.... I have the quad style headlights.
@bstunder...thanks for the info. I've looked at the can bus systems and they aren't cheap.
Old 11-18-2013, 12:39 AM
daviddup78's Avatar
Rep:71
well i got the GP thunder in my truck
it have the quad style and they work and you can get them off ebay for around 60 bucks
send me a private message if you want to know where i get mine
and i have the same ones on my 4wheeler, and truck and car i used to have
no issues
Old 11-18-2013, 03:32 AM
Rep:54
Thanks for the info David. How long have you had them in, in any of your vehicles?
Old 11-18-2013, 06:45 AM
gcscott's Avatar
gcscott gcscott is offline
Rep:1043
I think you should read this post about installing HID lights. He sums it all up perfectly and has great advice.
http://www.ramforumz.com/showpost.ph...5&postcount=13
Greg
Old 11-18-2013, 08:11 AM
GilAlex's Avatar
GilAlex GilAlex is offline
Vehicle: 2013 RAM 1500 Express RCSB 4x4
GilAlex is on a distinguished road
I have a 2013 Express. I put Spyder HID with 10000K bulbs installed by ProTuningLab. They inclued a harness that goes right back to the Battery. Works great. Now I hate how my high beams look.....
Gil Alexander
2013 RAM 1500 Express SB 4x4 - Flame Red
Old 11-18-2013, 10:08 AM
rkuhl84's Avatar
rkuhl84 rkuhl84 is offline
Vehicle: 2013 Ram 1500 Sport QC
Rep:88
rkuhl84 will become famous soon enough
10,000K?? Yikes. That's a really blue color temperature. Nearly all (if not all) factory HID systems use around a 4,300k color temperature since it provides the most lumens per watt of power.
