Old 05-04-2013, 02:35 AM
landozer18's Avatar
landozer18 landozer18 is offline
Vehicle: 2012 Ram 1500
Trim Level: Gladiator package
Color: Black with chrome
landozer18 is on a distinguished road
Default 2012 ram 1500 airbags
Tomorrow I pick up my new truck posted above and I called yesterday to my favourite parts store and my usual guy and told him to price out airbags and he said no, we keep have to warranty them in those new coil rear ends. I told him we see alot of people at work running zero pressure in there air bags and thats probably why!*I work in a tire shop as an apprentice mechanic so anytime a tire guys see's flat air bags he calls me over to verify.*
What do you guys think though? I really want air bags for when I rarely run my traillers.
Old 05-04-2013, 03:23 AM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
I have the Airlift 1000's installed on my truck and haven't had any issues. I haven't heard of anyone having problems with either Airlift, Firestone, or TLC products. You'll be fine adding them to your truck. They're definitely a big help when it comes to hauling.
Old 05-04-2013, 03:31 AM
landozer18's Avatar
Thanks again Brandon!
Old 05-12-2013, 09:36 PM
h2oman's Avatar
h2oman h2oman is offline
Trim Level: Express 4X4
Rep:349
They've only been around since '09 on the coil rear springs. What could possibly be wrong when so many are running them? They are easily obtained on Amazon or TLC on this site.
333Half the beast
I used to be
Old 05-13-2013, 01:02 PM
landozer18's Avatar
I get a nice discount from the parts stores we use from work
Old 05-22-2013, 01:07 PM
audio1der audio1der is offline
Vehicle: 2012 Dodge Ram
Color: Dark Red Cherry
Rep:201
audio1der has a spectacular aura aboutaudio1der has a spectacular aura aboutaudio1der has a spectacular aura about
I run the Airlift 1000's with 5-10 psi when not towing, and hardly notice they're there. Pump'em up to 30psi for towing and it completely eliminates any sag, and helped eliminate sway.
For $112 shipped to Canada and easy self install, it was a no-brainer. I was not a believer, but am a total convert now that I have tried them.
'12 Ram 1500 4x4 Sport CC;Airlift 1000, Moroso air/oil can, S&B CAI & scoop, 87mm P/KE/P/TB, Jet 180, Magnaflow
Old 05-23-2013, 03:13 AM
landozer18's Avatar
Thanks audio Im going to do them sometime this summer.
Old 05-23-2013, 06:48 AM
Outdoorsman2012 Outdoorsman2012 is offline
Vehicle: 2012 Ram Outdoorsman
Trim Level: Oudoorsman
Rep:39
Outdoorsman2012 is on a distinguished road
I have airlifts also, extremely happy with. I ran seperate lines and recommend you do too. I haul a decent amount of firewood and they work great. If you run trailers with a wdh hitch make sure that the hitch is set up proper before bags are aired up and air up bags only to compensate for weight in the truck. I pull a 7500 lb TT and usually have bags anywhere from 10-15 psi but air them up to 35 psi when hauling wood. If you don't use a wdh then air them up to max 35 psi and hitch up. If you want truck to settle a little more let air out, don't add air when hitched up. Just my 2cents. This is all in manual
Old 05-23-2013, 11:24 AM
Rep:201
^ That's true, but there are few things involved. I have to play with mine as I'm trying to get my trailer more nose-down but I'm at the bottom of my drop shank. If I air down I may have to adjust the # of chain links again, as if it gets more nose-down it will affect the weight balance F/R of the truck.
Old 05-23-2013, 11:06 PM
landozer18's Avatar
Outdoors mans thanks for the advice whats wdh hitch mean?
Never seen wdh
