Old 05-04-2013, 06:17 AM
beavermosh beavermosh is offline
Vehicle: 2013 Dodge Ram Big Horn 4x4
Color: Grey
Rep:15
beavermosh is on a distinguished road
Default Rough Country Leveling Kit 2013 Dodge Ram
I purchased the Rough Country leveling kit for my 2013 Dodge Ram Big Horn 4x4 (with 500 miles ) and figured I would share my installation with everybody.
http://www.roughcountry.com/suspensi...1500-ram_2.php
First off, I paid $130 for the kit which includes both front and rear spacers. There is no reason to use the rear spacers if your goal is to level the truck. I am not sure I understand why the rears are included in the leveling kit because if you were to install both it would be just as unlevel as the stock suspension. In fact, with only the fronts installed it is 0.5" lower in the front but much more reasonable than stock.
I have not yet, due to time constraints, gone to the tire shop to get my front suspension aligned. YOU MUST ALIGN THE SUSPENSION AFTER THIS INSTALLATION. The spacers cause significant positive camber that will unevenly wear on tires. It looks like the lower A-arm has an eccentric that will adjust the angle of the strut and in turn adjusting the positive camber back to 0 degrees. 4x4s are generally configured with 0 degrees of camber... truck lovers, correct me if I am wrong here.
I followed the installation instructions.pdf for the most part. The 2013 Dodge Ram has a 16mm sway bar nut which is different than the instructions, other than that its the same. However, when installing the extended strut I would highly recommend to unbolt the brake caliper because during re-installation the lower A-arm has to pivot even further downward putting strain on the brake line and the tire pressure line.
Now for the fun part! Here is one picture from my installation (basically taken at random), before picture, after picture, and a badass gif of them both.
Camber eccentric adjustment
Before
After
Badass GIF
Old 05-04-2013, 06:24 AM
ARFF65 ARFF65 is offline
Vehicle: 2013 Ram
Rep:23
ARFF65 is on a distinguished road
How long did the install take?
Old 05-04-2013, 09:49 PM
anakin1's Avatar
anakin1 anakin1 is offline
Vehicle: 2012
Trim Level: Bighorn
Color: grey
anakin1 is on a distinguished road
So u didn't put the rear spacers in? Looks good
Old 05-04-2013, 10:42 PM
Color: Grey
Rep:15
The install took around 3 hours. If you have all the tools required, can read the attached instructions, know a thing or two about suspension, and have a second person to occasionally help then you could do it in 2 hours.
The rear spacers are not installed. And thanks, I agree.
Old 05-05-2013, 03:40 AM
Relewis3's Avatar
Relewis3 Relewis3 is offline
Vehicle: 2011 Dodge Ram 1500 Sport
Relewis3 is on a distinguished road
I think it looks great! With the rough country kit what size tire can you go to with out needing some sort of spacer to prevent rubbing? Thanks!
Old 05-05-2013, 09:54 AM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:358
Looks fantastic. Great job.
333Half the beast
I used to be
Old 05-05-2013, 01:48 PM
Vehicle: 2013 Ram
Rep:23
From the looks of the instructions, you have to disconnect a ton of stuff so you can drop the springs and put spacers in above them. Can you shortcut the install with a spring compressor?
Old 05-05-2013, 06:59 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
LOOKS GOOD!
Thanks
Jeremiah
Discount Auto Performance
Old 05-06-2013, 12:13 PM
MangoTangoMofo's Avatar
MangoTangoMofo MangoTangoMofo is offline
Vehicle: 2010 1500 Sport 5.7L Hemi
Trim Level: Sport Quad Cab
Color: Mango Tango
Rep:98
MangoTangoMofo will become famous soon enough
Looks Great! I love the Rough Country kit.
5x11x22 Magnaflow with a resonator delete // Rough Country 2.5F&1.75R level kit // 17 XD Cranks // 35x12.5x17 Toyo MT's // Air Lift 1000 // Armor Thane bed liner // Century Ultra Sport Canopy // Yakima Roof Rack // Mopar side steps // Custom Browning Mudflaps
Old 05-07-2013, 08:38 PM
Color: Grey
Rep:15
I wouldn't know. I didn't put the spacers in for bigger tires or wheels.
It's basically the same job as replacing the shocks. In a nut shell, you have to remove the wheel, brake caliper, top upright bolt, sway bar bolt, and the strut bolts. I'm not entirely sure that you would be able to use a strut compressor but that would debatably be just as difficult. If you don't have basic mechanical knowledge then I would just have the shop do it.
