Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 05-04-2013, 07:26 PM
Stusmobile Stusmobile is offline
Vehicle: 2013 Quad Cab
Rep:98
Stusmobile will become famous soon enough
Default 2002 sport, brakes kicking my butt
2002 4wd, rear wheel abs, 5.9 quad cab.
Failed inspection on a bad rear caliper/rotor.
Swapped out for new calipers and rotors on both sides. Started bleeding the brake lines and the abs valve to rear line blew through. Swapped out for a new line and started bleeding all four corners. Also swapped the drivers front flexible as the previous owner thread locked the lines there . Found the previous owner had used thread lock on the bleed nipples too so ended up swapping the front calipers too.
Got fluid at all four corners, but still zero brakes. Thinking that the master cylinder seals may have got screwed up when the line blew, swapped out to a new master cylinder. Bench bled the master, whilst hooking it up heard something loose in the brake booster. Ended up swapping out for a re-manufactured brake booster too.
Re-bled all four corners of the truck, fluid at all bleed nipples and still zero brake. Cracked all four caliper nipples and let the fluid gravity bleed for an hour, fluid at all four nipples. Vacuum bled all four corners again, same thing. Can get about 1/2 inch of brake pedal after 6 or 7 pumps but once you take your foot off the pedal, the brake is gone (engine off). With engine running there is zero brake at all and no amount of pumping firms the pedal.
As far as I can see, even if the rear wheel ABS is air locked, I should still be able to get front brakes. Front lines run from master cylinder down to the drivers side wheel well into a block. Block splits with a hard line under the engine to passenger side front. Other line is drivers front flexible.
Planning to bypass the rear ABS tomorrow, direct from master cylinder to the rear lines, after that I am lost. No ABS or brake lights on, no codes in the freeze frame data, nothing showing on my OBD II reader (OBD Wiz to a netbook) for the brakes at all.
Never had an issue like this and all advice welcomed.
Old 05-05-2013, 06:19 PM
HemiLonestar's Avatar
Rep:274
Did you bleed the ABS module (need a DRBIII or compatible to do it)?
"Big Red"
2006 Charger R/T
Old 05-06-2013, 08:26 PM
Rep:98
Actually bypassed the ABS to rule out any air locks there, still having the same issue.
Old 05-07-2013, 12:39 PM
Chris65 Chris65 is offline
Vehicle: 2007 Dodge Ram
Color: silver
Rep:45
Chris65 is on a distinguished road
Do you bleed manually?
For blleeding the abs system u need a "puls-bleeder".
This machine sets the system with ~2bar under pressure and pulses the brake fluid through. Without you will not get the air out.
Old 05-18-2013, 12:51 PM
Rep:98
And fixed.
After ignoring the truck all week the obvious jumped out at me as soon as I slid under her to begin bleeding. Drivers side front caliper was wrong, the bleed nipple was on the bottom, not the top. Even a buddy who works at the local Dodge dealer missed that little issue, sometimes you really need to walk away and take a good break.
Took the caliper back off and returned it to the local store, turns out every single drivers side caliper they had was wrong, every single one was for the passenger side. Luckily they located another nearby, 15 minutes after getting home, the truck was rolling around the block with all four brakes working correctly.
