Functional ram hood + vararam - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 05-04-2013, 10:25 PM
Jerrad Jerrad is offline
Rep:54
Jerrad will become famous soon enough
Default Functional ram hood + vararam
http://www.apmautomotive.com/
It seems as though this hood would compliment the vararam air grabber like a charm but how could you possible keep mud or water out of the intake
Old 05-04-2013, 11:04 PM
Gantman's Avatar
Gantman Gantman is offline
Vehicle: 2016RCLB4x4/44-45
Trim Level: Tradesman w/3.92 LSD
Rep:999
Well simple my Ram brother! It WILL allow water or mud into your intake if driving in said environments. It's a great Ram Air Hood as I have wanted one for a long time BUT! The risk for me far exceeds the reward as I drive daily and when it rains, it pours out here in Texas. I can only imagine driving on the freeway at 75 mph through a downpour with a Ram Air Hood and VaraRam AirGrabber combined. But you know the ole sayin? "YOU DO YOU! Don't do me bud!"
Total Chaos UCA's, Fox 2.0 IFP Coilovers and shocks, TTC-1223V variable rate coil springs.(Mods list)
Old 05-04-2013, 11:33 PM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
I don't think the Vararam would seal to that hood properly without some mods. Its designed to ram air into the stock airbox. That's not to say it couldn't be done. While you're at it you might as well fab a flapper for the opening that works off a linear actuator with a switch in the cab to keep mud and water out of the intake when needed!
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
Old 05-05-2013, 06:37 AM
Chris b's Avatar
Chris b Chris b is offline
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
This hood comes with its own air box to keep water and stuff from getting in the intake
SPONSORED BY
BULLY'S PERFORMANCE
Old 05-05-2013, 06:17 PM
Rep:54
Yeah I noticed after the fact that it directs the air off to the side where the original air box is, wouldnt work with the vararam anyway. Has anyone seen or heard of improvements out of this system though?
Old 05-05-2013, 09:38 PM
RAM EM's Avatar
Color: Grey
Rep:195
I'm sure it could be modded to work, but I don't know if it would be worth the effort. The Vararam is already a "ram air" system by design.
Old 05-05-2013, 10:23 PM
CdnoilRAM CdnoilRAM is online now
Rep:3347
I have the APM hood and had a Suncoast ram air hood on my last truck. Rain and snow are not an issue with either hood type based on the design. Both have rain channels and drain holes to allow water to drain out to non-critical areas under the hood.
The APM hood will not work with the vararam, you would have better luck opening up the vents on the sport hood. If you want ram air then the vararam will work better if you don't swap hoods. I prefer the hood version myself because I'm installing a supercharger and I can direct more cold air towards the s/c's filter, not that it will make a huge difference once the air starts getting heated from the compression.
