Old 05-05-2013, 07:29 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
BRH, have't seen you post in awhile. So with your stock tuning the efan comes on at 190 deg F? Mine doesn't come on until IIRC 222 deg F. That's what I always understood stock to be.
Why'd you remove the tune, anyway?
I know the default values on my Diablo Trinity were 222ºF, but not sure what stock really is???
I know it doesnt make sense to me either, I had it set for around 190ºF when I was tuned, but I removed the tune and back to 100% stock when our track closed for the year in September...
(no use running 94 octane when prices went crazy here).
My tune is definitley wiped from the truck, plugged it in just recently to confirm
Is there anyway the fan temp settings I programmed somehow stuck???
I remember my track bud MGRAM-10 said he ran his E-Fan for a couple weeks right after we installed it without a tune or a 180º stat and it worked fine for him too.
Our track just opened again on Friday May 03 and I will be tuning again soon,
right after my "tune-free" Ram gets it's trans inspected before the warranty is up.
...Then start prepping for my new RIPP kit. MGRAM's install turned out great 490HP on the Dyno!!!
Old 05-05-2013, 07:38 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
gotcha that makes sense. I was using a 93 tune but changed to the 87 tune due to gas price. Nearly $1 more now for premium
Sean
Old 05-12-2013, 02:42 PM
Rakal's Avatar
Rakal Rakal is offline
Vehicle: 2010 Ram 1500
Rakal is on a distinguished road
Put it in today. What a pain in the ass to get that clutch fan bolt off. Anyways the new fan is MASSIVE and works awesome!
Thanks everyone!
R
Old 05-13-2013, 08:50 AM
snrusnak's Avatar
Rep:1385
Superchips had all kinds of issues in regards to the fan settings when I tried the tuner on my truck. With it tuned(even leaving the fan settings stock according to the tuner) the fan would run constantly. They did correct it and told me stock is 222deg F on for the efan. And it appears to work correctly(like stock) when I leave the fan settings stock. Maybe diablo has some similar issues with these settings as well??? Obviously, there can be errors in programming.
Sean
Old 05-14-2013, 12:30 AM
Gecko's Avatar
Gecko Gecko is offline
Vehicle: 2004 Quad Cab
Trim Level: SLT 4x4
Rep:221
Gecko has a spectacular aura aboutGecko has a spectacular aura aboutGecko has a spectacular aura about
I've seen a few guys have done this before but what is the point of changing the fan out?
Supercharged, cammed, other things too!
Old 05-14-2013, 09:05 AM
Rep:554
Mechanical clutch fan is a parasitic drag on your crank (HP loss)
just how much is still up for debate, but it is less drag on your engine with one less accessory to turn.
I like how replacing two stock fans with one large one frees up engine bay space.
$100 mod is worth the extra room and clean look alone IMHO.
..also makes more room for my RIPP supercharger ...coming soon.
Old 05-14-2013, 01:54 PM
Gecko's Avatar
Trim Level: SLT 4x4
Rep:221
So is this possible on 3rd gens as well then?
Old 05-14-2013, 03:31 PM
snrusnak's Avatar
Rep:1385
^no........................
Sean
Old 05-14-2013, 04:37 PM
Rep:554
For a 3G Ram, search "Ford Taurus E fan swap"
http://www.ramforumz.com/showthread.php?t=126383
its a little more involved vs the 4G Hemi plug&play solution.
Old 07-31-2013, 05:38 PM
bouf0010's Avatar
bouf0010 bouf0010 is offline
Vehicle: 2013 Dodge Ram 1500
bouf0010 is on a distinguished road
Hey blackramhemi, where did you find that fan in canada for $100??
T-1000 HF 93 Tuned - S&B CAI w/custom air scoop - Moe's 87mm tb - Silver Ceramic JBA Shorties - Magnaflow Y-pipe - GT Custom 22" muffler - V6 E-fan mod - 180 t-stat - Catch Can - bielstein shocks - 2" rear drop coils - Cooper Zeon LTZ 305/55R20
