Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Dodge Ram Decals
Old 05-05-2013, 05:37 PM
turbohawk's Avatar
turbohawk turbohawk is offline
Vehicle: 2014 1500 4x2 5.7 8spd
Trim Level: Lonestar QC 6'4" bed
Rep:44
turbohawk is on a distinguished road
Exclamation Concerned about Transmission temps...too low?
Ok, been reading a LOT of stuff about Dodge/Ram and the engines. This site (http://www.allpar.com/model/ram/dodg...owertrain.html) has a LOT of info about changes to the 2013's specifically. Quoting here:
A segment exclusive on the 2013 Ram 1500 is a new thermal management system, designed to quickly raise the transmission fluid temperatures to cut parasitic losses and wear, improving fuel efficiency by 1.7%. It is enabled by an electronic thermostat which constantly monitors antifreeze temperature; once it’s hot enough, warm engine coolant is circulated through a thermal exchange unit which heats up the transmission fluid. In most vehicles, the transmission heats up independently of the engine. (The system also works for engine oil.)
Chrysler’s Dave Sowers said:
We get benefit from bringing both of them [oil and transmission fluid] up to operating temperature faster. The primary benefit comes in the transmission. In colder climates, you could drive a vehicle for hours in the winter and the transmission might never reach that 190° (F) for the most efficient operation. So what we do is use some of that hot engine coolant through the heat exchanger to bring it up to 190° as quickly as possible, and that gives us efficient operation very quickly.
This is a big leap forward in efficiency given most customers’ drive cycles and like I said, the fact that they might never get to that level of efficiency. We even use it with engine oil. You might think that once you start running the engine, the engine, the coolant and the oil are all the same temperature but that’s not true. We’re circulating coolant around where the combustion process happens to take all the heat out that we need to. What we’re going to do is heat the engine oil up to that – about 190° – as quickly as possible too. More benefit comes from the transmission than from the engine, but it helps in both cases.
Why do you say that more benefit comes from the transmission? Because the engine oil would’ve heated up eventually anyway. So we’re speeding up in the engine. In the transmission case we’re getting to where we might not have ever got in cold temperatures and low loads.
Now look at the photo of my temps...see a problem? My transmission temp has never been above 162 but my oil temp stays 10-15 degrees higher than coolant temp. Should I be worried? Crossed wiring with the respective sensors? If this Chrysler engineer didn't flub the numbers then it sounds like I either have a bad temp sensor, wrong sensor indicated (crossed wires) or this whole 190 degree thing is BS, OR my transmission cooling system is too good...
Old 05-05-2013, 05:42 PM
rraulston rraulston is offline
Vehicle: 2013 Ram Sport Crew Cab Hemi
Rep:7
rraulston is an unknown quantity at this point
mine is the same. Only when I tow will it go above 200.....I think I hit 220 once. Late time I was under the truck, it appeared the tranny cooler line ran close to the exhaust...interesting article
Old 05-05-2013, 05:54 PM
CharlieL CharlieL is offline
Vehicle: 2013 Ram 4x4 Crew Cab
Rep:116
CharlieL will become famous soon enoughCharlieL will become famous soon enough
I see nothing out of the ordinary with your temps. Your temps are very much in line with what I see on my truck. I haven't towed yet, so can't report any temp difference due to that. Also, from what I've read the "thermal management system" that heats up the tranny is only on the 8-speed.
Old 05-05-2013, 05:57 PM
turbohawk's Avatar
Rep:44
Ok, thanks guys for replying. That article didn't point out which transmission so I just assumed it was for all of them. Whew!
Old 05-05-2013, 06:17 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
My tranny temps are rarely over 160 (not towing). So I think you'll be perfectly fine. I've read else where that 160 is a good temp for them to be at during normal driving so I'm sticking with that. Honestly, that difference in temperature probably makes very little difference as well.
Old 05-06-2013, 03:15 AM
Brians RT's Avatar
Brians RT Brians RT is offline
Vehicle: 04 Ram 2500 4x4 RCLB 13 Ram RT
Trim Level: SLT, RT
Color: Atlantic Blue/Silver, Bright White
Rep:39
Brians RT is on a distinguished road
My trans temp in my R/T wont vet above 140. Even towing up the Grapevine out of LA my temp was at 129. It actually dropped going up hill towing 5k.lbs
04 Ram 2500 4x4 RCLB Hemi A5 4"lift 35's
13 Ram R/T Bright White
Old 05-06-2013, 11:11 PM
turbohawk's Avatar
Rep:44
Did your ambient temp drop significantly? Otherwise this makes no sense since it seems logical that a transmission under load is going to produce more heat than one coasting...wondering if the temp system is all that reliable/accurate?
transmission temperature
