Old 05-05-2013, 07:06 PM
2012Sport's Avatar
2012Sport 2012Sport is offline
Vehicle: 2014 Ram 1500
Rep:39
2012Sport is on a distinguished road
Default SUspension noise after Bodly Lift and Rear spacer
I recently put Bilstein 5100's up front and a 1.5" TGC coil spacer in the rear along with a RC 1.25 Body Lift. Since he install I am getting a lot more noise when cornering and hitting bumps and such. Has anyone else experienced this or should I be going through everything with a fine tooth comb?
Definitely hear the coils when braking and starting more. In the rear it sounds like a few different things making noise. This really has me worried.
Any thoughts are appreciated...
2014 White Ram 1500 Big Horn. OEM Projector headlights. F1 Backflip and Mopar bedrug.
Old 05-05-2013, 08:49 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
I've heard multiple times of guys not installing the hardware on the bilsteins in the correct order and it causing clunking and noises over bumps
Old 05-05-2013, 10:47 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2051
The coil spacers will also give you a bit more noise because now there's metal on metal contact between the spacer and the frame instead of just rubber as it was stock. But I'd double check your Bilstein install as well like gonefishin776 said.
Old 05-06-2013, 09:39 AM
2012Sport's Avatar
Rep:39
My thought was also the metal on metal of the spacer. Maybe shove a rubber spacer like the factory one between them to help?
I will also be going through everything with a fine tooth comb my next day off.
Old 05-06-2013, 12:48 PM
Rep:2051
If you could get a piece of durable rubber that would stand up in that application I'm sure it would help.
Since I added my Airlift 1000 bags mine has been a bit quieter. The 5 PSI in the bags helps push the spacer up against the frame a bit more. It also quiets down a bit once you had them on for a while and they wear in a little.
