Engine not rotating when starting - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 05-05-2013, 08:25 PM
jcmorozz jcmorozz is offline
Vehicle: 2003 Dodge Ram 2500 Quad Cab
jcmorozz is on a distinguished road
Default Engine not rotating when starting
I'm having an issue getting my truck started. I had this issue a month ago and it just went away, worked for a month and now is back. I have and haven't had any codes pop up. Im almost positive it is an electronic problem. I don't see how else it could be
1. Put Programmer Back to Stock
2. Cleaned Positive Battery Terminals & Replaced Ground Terminal as it had more corrosion then I like
3. Replaced Battery as it had a dead cell
4. Checked all wiring (Nothing out of the norm)
5. Checked all Fuses and Relays
6. Replaced Ignition Switch
7. Bench Tested Starter (Working just fine) - Battery Voltage to Starter Solenoid Checks out
8. Replaced Crankshaft Position Sensor
I was going try the Transmission Range Sensor, or PCM but couldn't get either at the part stores. Anyone have any similar issues or ideas? I'm going try to find a TR Sensor or PCM offline
Old 05-10-2013, 02:24 PM
Hemizone's Avatar
Hemizone Hemizone is offline
Vehicle: 2007 Dodge Ram
Hemizone is on a distinguished road
Did you check the fuse box itself? Sometimes that connection gets a little corroded.
You Have Been Hemizoned
Old 05-17-2013, 03:49 AM
Clifford05's Avatar
Clifford05 Clifford05 is offline
Vehicle: 2005 Ram Pick Up
Trim Level: SLT Sport
Rep:20
Clifford05 is on a distinguished road
Stop changing anything, buy yourself a test light and a case of beer or soda and call a helping hand over to drink and turn the key to start while you check for voltage here and there... now that you change the ignition switch you may need to reprogram it also depending on key color/system.
Old 05-18-2013, 10:09 AM
HemiLonestar's Avatar
Rep:300
HemiLonestar is a jewel in the roughHemiLonestar is a jewel in the roughHemiLonestar is a jewel in the roughHemiLonestar is a jewel in the rough
In the title you said it isn't rotating. Is the engine not spinning when you crank it (i.e. hydrolocked) or is it spinning and just not starting (i.e. no ignition)?
"Big Red"
2003 Ram 1500 QC Hemi Lonestar "Big Red"
2006 Charger R/T "Little Red", 2005 Magnum R/T
(Mods list in profile)
Old 05-27-2013, 10:59 PM
I've checked several things with a voltmeter and didn't have much luck, I changed the PCM and it didn't help the situation.
Hemilonestar - It doesn't attempt to spin at all (it doesn't not rotate)
Old 05-27-2013, 11:05 PM
and what do you mean reprogram the ignition switch - I just let the new ignition switch turn on for a couple mins prior to trying to turnover
Old 05-27-2013, 11:44 PM
Rep:3347
If it doesn't even attempt to turn over then that points me to the starter first. Are you getting voltage across the starter terminals? If yes, is the starter itself toast or at least the starter solenoid may be worn out and need rebuilding/replacement. Does the good ol' hammer method work to get it going?
Old 05-28-2013, 02:45 AM
S.C. Express S.C. Express is offline
Vehicle: 2012 Ram Express
Rep:63
S.C. Express will become famous soon enough
Nevermind, saw you did replace battery. Your cable that runs from the battery to the starter can corrode completely thru the whole length of the cable. I've cut some in half and found acid corrosion had destroyed the entire cable.
Jones MaxFlow 18" muffler swap, Green Performance drop in air filter..
Last edited by S.C. Express; 05-28-2013 at 02:49 AM. Reason: Edit for lack of reading
Old 05-28-2013, 02:54 AM
Rep:2962
Is your starter spinning ?
is it engaging your fly wheel ?
Old 05-28-2013, 10:35 AM
Rep:300
I had an intermittent start issue for awhile, turned out to be a bad connection to the starter. Took it off, cleaned it, put it back on and haven't had an issue since.
"Big Red"
