Old 05-28-2013, 11:40 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
If you are hearing the starter spin but the engine is not spinning that means the starter gear is not engaging the flywheel. It's likely what Cdnoilram said.
Sean
Old 05-28-2013, 10:04 PM
jcmorozz jcmorozz is offline
Vehicle: 2003 Dodge Ram 2500 Quad Cab
jcmorozz is on a distinguished road
The starter is getting power to it, I pulled the starter and had bench tested already. When I saw the ignition isn't cranking, I mean nothing like It might as well just be in run (It doesn't attempt to turnover). At this point I may have just replace the starter as the starter is getting power but nothing is happening. I replaced every other part possible
Old 05-28-2013, 11:05 PM
I push the skinny pedal
Rep:3277
Can you physically turn it over by hand? I mean wrench on the fan nut and able to rotate the assembly at all? I just want to rule out any physical issues.
Kurtis
Old 05-29-2013, 08:01 AM
snrusnak's Avatar
Rep:1385
With someone holding the ignition in the "start" position, crawl under the truck and bang on the starter with a light hammer(don't try to break it, but hit it firmly). Just because the starter is getting power doesn't mean it is engaging. 9 times out of 10 the hammer trick works. If it does, then you know it's time to rebuild the starter(or replace).
Sean
Old 05-29-2013, 09:17 AM
tjbiker031's Avatar
Vehicle: 2002 Dodge Ram
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
You mentioned you have power to the starter....Do you have a good ground? Do you have power coming out from the ignition switch to the starter? Does the starter click when you try to crank it over?
Do you have a manual or atleast a few wireing diagrams? I have a e-copy of the factory manual if you need one to help you diagnose this....
