Old 05-05-2013, 09:36 PM
BryBry13's Avatar
BryBry13 BryBry13 is offline
Vehicle: 2012 Ram 1500 Express
Color: Mineral Gray Metalic
Rep:33
BryBry13 is on a distinguished road
Default Question for the Wheel & Tire Guru's
I have a 2012 Express 4X4. Can I fit 20x10 wheels with a -12 offset wheel 305/55/20 tire under my truck without a leveling Kit? I know they will stick out about 1-1/2" further than stock. I just don't want them to be hitting the fender when I turn. Any help will be greatly appreciated. Below are the wheels I want.
Smitty Built Cab Length Nerf Bars, Wade SureFit Mats, LED License Plate & Interior Bulbs, Upper and Lower Billet Grille Inserts, Debadged, Pioneer AVH-X5500BHS, Boyo Back-up Cam, Flowmaster Super 40, Flowmaster 5" Tips, DB-ALL Remote Start, Mcgaughy's 2" Rear Drop Coils, Chrome Brake Painted Drilled & Slotted Rotors, Power Stop Ceramic Pads, MGP "RAM" Caliper Covers, 22" Dolce DC-46 Wheels, Nitto NT420s 305/45R22 Tires ........... So Far............
Old 05-05-2013, 10:37 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2032
They're gonna stick out a lot more than 1.5".... You're looking at closer to 3" at least.
As far as them fitting I'm gonna say no.... With that width and and offset you're probably going to rub while turning. I definitely could be wrong though. I'm just going by what I've read and experienced. With my 20x9 -12 offset and 35x12.5 tires on a 2.5" level I still rubbed. I know your tires will be smaller but I'm still doubting it working.
Old 05-05-2013, 10:42 PM
Grubrunner's Avatar
Rep:3883
Without a leveling kit, no chance.
Grub out!
Old 05-05-2013, 10:45 PM
Grubrunner's Avatar
Rep:3883
Okay, I just re-read your post. I thought you said 35X12.5 on 20X10 rims. It took for the second reply to pick this up.
With 305/55/20 I'm not sure at all..... but I doubt it.
Grub out!
Old 05-06-2013, 05:18 PM
BryBry13's Avatar
Rep:33
Thanks. Actually it's a 33"x 12.0" tire. I thought I would be cutting it close with the width of the tire.
Old 05-07-2013, 12:31 PM
jake09's Avatar
jake09 jake09 is offline
Rep:56
jake09 will become famous soon enough
Should work and will only rub slightly imo
2009 Ram 1500 4x4
6" superlift, 1.25" bl, 37 nitto mg's, & too much to list..
