leveled! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
Old 05-05-2013, 10:22 PM
RAM4life21 RAM4life21 is offline
Vehicle: 2002 dodge ram
Trim Level: new body style
RAM4life21 is on a distinguished road
Default leveled!
hey guys
i turned my torsion keys all the way! now the front look taller than the back. i was wondering if i buy 2in rear shocks, would that do the trick? or what should i do? dont get me wrong i do love the clearence i get now! so let me know what ya think.
Old 05-05-2013, 10:56 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Well for one if your front is higher than the back you didn't level it. You went too far. You could just back them off a bit.
Shocks won't lift your truck at all. Shocks have nothing to do with the height of the truck, they just prevent the truck from bouncing too much. You would need rear blocks or re-arced springs.
Old 05-06-2013, 08:04 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Cranking your torsion bars as far as they will go is a very bad idea. I don't know how much lift you got by cranking them that much but about 2" (maybe....maybe 2.5" but I personally would not go over 2") is really all that is safely recommended. Cranking the torsion bars puts extra stress on the front suspension components and creates angles that your suspension wasn't designed to operate with. This can cause a number of problems, one of them being accelerated wear on the front end. Also, if you haven't noticed already I bet when you accelerate heavily in your truck you will get a brief shimmy from the front end. It will be even more pronounced in 4x4. This is because your CV's are at an extreme angle. All of these are reasons why cranking should be limited to about 2". Even with only 2" of lift you really need new front shocks to prevent them from overextending on dips and potholes.
I'm all for cranking if you wish to level by lifting. It just needs to be done properly and in moderation. I ran my 04 for about a year with the torsion bars cranked before I swapped to level by lowering with McGaughy's rear drop shackles. I love it but lowering isn't for everyone. If you want to keep it lifted I recommend you get it back down to the 2" mark and spare your front end and you also won't need to mess with the back. If you lower the front to where it is about 3/4-1" lower than the back that will be about the 2" mark as the front sits 2-3/4 to 3" lower than the back from the factory. To the eye, the truck will probably look level at this height.
Also, give it a day or two to settle after you get it where you want it and get an alignment!! I guarantee that your alignment is way off right now and I wouldn't be surprised if they had trouble aligning it with the bars cranked all the way.
Old 05-06-2013, 08:05 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
I strongly agree with starquestbd22 ^^^^^^^^^^^^^^
Old 05-06-2013, 09:47 AM
so i should just lower it alittle bit!? then ill be good right?? and yes my alignment is off. lowering it would help the drive shaft. would i be better off buying actual torsion keys! thanks for the help and preventing my truck to break in the future!
Old 05-06-2013, 10:37 AM
Rep:367
Yes, you should lower it back down to the measurements I posted above or at the very least just lower it back down to where the front does not sit higher than the back. Measure it and eyeball it. Often a truck that measures slightly lower in the front will actually look level. Check it again after you drive it a few miles as the front end may settle a bit more when the suspension components move around a bit. Don't waste your time on aftermarket torsion keys. They are worthless and will not do anything for you that you can't do for free.
Old 05-06-2013, 02:43 PM
SwampDonkey2012 SwampDonkey2012 is offline
Vehicle: 2011 Dodge RAM Sport Crew
Trim Level: Sport w/ Sunroof
Color: Pearl Black
Rep:13
SwampDonkey2012 is on a distinguished road
Just got mine Leveled. Did the Bilstein 5100's all the way around. I seem to find from everyone I talk to, that this is 'The Only' way to level these trucks. My truck looks so much meaner and rides even better than before.
I would save your money and do it the right way. IMHO
Rep:1900
he has 2005, different suspension set up. he can't use bilsteins
Old 05-06-2013, 03:04 PM
i have a 02 ram
Old 05-06-2013, 03:06 PM
i was thinking about the daystar leveling kit. its a 5in leveling kit.
