Old 05-05-2013, 10:59 PM
haggus75 haggus75 is offline
Vehicle: 2012 Dodge Ram
Color: Blue
haggus75 is on a distinguished road
Default Tire pressure
Hi,
Small question... I'm my door it say's 35PSI for tire pressure on my Ram 1500 Sport 2012, but on the tire it say's 44. Is it Ok to go over 35 and at what pressure does the TPMS will start to notify me on the higher pressure.
Thank you,
Martin
Old 05-05-2013, 11:01 PM
brandonjansen's Avatar
brandonjansen brandonjansen is online now
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2032
On the tire it probably says 44 is the max PSI. The door would tell you the recommended PSI which is generally what you should run in stock tires. For towing or hauling you could definitely air them up though.
I don't think the TPMS sensors should go off with too much air. I believe they're only set to tell you when they go too low. I could be wrong though.
Old 05-05-2013, 11:56 PM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
The tire pressures sent from the factory are too high imo. I think mine were like 46. I aired down to 36.
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 05-07-2013, 09:00 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Rep:1109
I run mine at 36 as well.
Bilstein 5100s @ 2.1", CF wrapped dash, De-badged, Extang Solidfold tonneau, Goodyear Wrangler Duratracs (285/60/20), Husky Weatherbeaters, Magnaflow 18" muffler, Mufflex 5" tips.
Old 05-08-2013, 12:09 PM
05MinGryHemi 05MinGryHemi is offline
Vehicle: 2005 Dodge ram1500
05MinGryHemi is on a distinguished road
It depends on your tires. Stick tires should be run at the psi it says on the door.
