2012 Idling High RPM - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Old 05-06-2013, 10:02 AM
deerhunter1 deerhunter1 is offline
Vehicle: Ram 1500 Outdoorsman Mossy Oak
Trim Level: Outdoorsman
deerhunter1 is on a distinguished road
Default 2012 Idling High RPM
Sometimes when I start my truck, the RPS go up to 1800-2000, and when I shift into gear, it jolts the truck. It doesn't happen all the time, just sometimes. Is this a problem?
Old 05-06-2013, 10:52 AM
SFVDOC's Avatar
SFVDOC SFVDOC is offline
Vehicle: 2012 Ram 1500 CC 4X4
Rep:92
SFVDOC will become famous soon enough
Mine does that after a cold start but the rpms drops down after a minute or so.
Old 05-06-2013, 11:40 AM
Asur Asur is offline
Vehicle: .
Rep:4373
Same here, cold start RPM's are around 1800, then fall to 1500, then 800 then 600 then 500 when driving and stopped, does this over a minute. Always has, I am guessing always will.
Old 05-06-2013, 12:14 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Yup, exactly what Asur said. The trucks do that to help warm up the engine and fluids which will make it run better and is easier on the engine. It's never a bad idea to let your truck warm up for a couple minutes on a cold start.
Old 05-06-2013, 04:24 PM
Okay, it may still be okay, but I'm in VA and it's been in the 70's here for the past two weeks, and I didn't see it start doing this until over the last two weeks randomly. May not be a problem, but wanted to be sure.
Old 05-06-2013, 04:41 PM
Gantman's Avatar
Gantman Gantman is offline
Vehicle: 2016RCLB4x4/44-45
Trim Level: Tradesman w/3.92 LSD
Rep:999
I think you're going to be ok deerhunter. With 14500 miles on my Hemi, even at 85*F outside, leaving work for home, been sittin 8 hours, my baby still idles after startup at 1800-2K for about 30 seconds and starts to drop to 800, 600, 500, no wait 600. I have come to the same conclusion that this Hemi program is constantly searching to get to its optimum operating temps while still trying to provide us drivers the get in, start, and immediately place it in "D" an go. I guess I'm still old school and let my baby warmup idle til she comes down, then I know my Hemi's happy.
Total Chaos UCA's, Fox 2.0 IFP Coilovers and shocks, TTC-1223V variable rate coil springs.(Mods list)
Old 05-07-2013, 06:30 PM
PaulMys PaulMys is offline
Vehicle: no car
Rep:3238
Yup. Same here. mine usually is around 1200 - 1300 for half a minute, then idles down nicely. Has done this from day one regardless of temp.
Old 05-07-2013, 06:47 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
I'm sure it has to do with the F.I. system. Engine starts up cold the O2 sensors are not heated up yet, the ECU keeps idle RPM up so engine doesn't load up as more fuel is being used on cold start engine. It doesn't take long as ECU trims fuel back and O2 sensors start giving more feedback to ECU for fuel curve. Before long ECU goes into closed loop with all sensors in play and idle goes down. Much more complicated, this is short version.
2016 Challenger R/T Hemi 6-speed.
2012 Equinox 2.4...Wife's Ride
2014 RAM 3.6/8 speed/3.55 gears........Gone.
"Life's hard, it's harder if your stupid."
How would you know?
