Old 05-06-2013, 01:26 PM
Hemirt Hemirt is offline
Vehicle: 2013 Ram 1500 R/T
Trim Level: R/T
Color: Gray metalic
Hemirt is on a distinguished road
Default Catch Can Hookup
I am going to put a catch can on my 13Ram RT. I truly believe in their collecting oil and keeping it out of the intake system. Have it on my challenger RT 5.7. I know the intakes are different on the Ram trucks for the same engine, so I wanted to see clearly where the hoses go on the Ram engine. Pics would be very helpful.
Your help is appreciated.
Old 05-06-2013, 01:53 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
Do a quick search of Catch Can using the search function here on the forum. (be sure to select "in title" not "in post" you'll yield better results. There will be plenty of threads in there for you to read with pictures. Even one I think of someone with a 2013 asking about catch can fitment
Old 05-06-2013, 03:09 PM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:363
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
yo can go look on billet technologie web site, if i remember right they have the install instruction with pics on the site, at leat mine came with a install inst and pics,..
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover
Old 05-06-2013, 04:06 PM
Trim Level: R/T
Color: Gray metalic
Will do, thanks
Old 05-06-2013, 04:51 PM
Rep:2657
I read somewhere that BT may have to machine a longer bracket for the 8 speed, something about some hoses
You can contact them & inquire about it
I called them when i wanted to buy the catch can for my '09, mostly because i wanted to make sure that i received the right part for my Ram HEMI
with mine, the hoses have the braided metal over them & it was easier to run the hoses this way, which some people may think is backwards, but to the catch can there is no certain way for the oil & fumes to flow
On your Ram, the stock hose runs from the Red electrical connector to almost a straight line back to near the throttle body.
I kept my stock hose, because the guy that i have do my smog tests, told me that in California, not only does the smog system have to function properly, it must pass a Visual test & it can Not be modified. When it is time for a smog check, the can will still be there, but the hoses will be removed & the stock hose will be put back on, just for the test
