Old 05-06-2013, 07:10 PM
maximus007's Avatar
maximus007 maximus007 is offline
Vehicle: 2010 Ram Crew Cab
Color: Light graystone metallic
Rep:12
maximus007 is on a distinguished road
Default Trans Temp pulling 6000 to 7000lbs trailer?
Just curious what the trans temp should be pulling a Travel Trailer about 6500lbs? Any input would be appreciated. Thanks
Bilsteins set at 2.8, rcx1.25 bodylift,fuel krank wheels with 35in toyo at 2s, tinted windows, K&N drop in,14" Magnaflow muffler, Diablo Trinity 1000 hemifever tuned, airlift 1000s, 2500 fender flares color matched, spray in bed liner, moroso catch can, 180 t-stat
Old 05-07-2013, 05:56 PM
maximus007's Avatar
Rep:12
what should your trans temp be while towing?
Old 05-07-2013, 08:48 PM
GearHd6's Avatar
GearHd6 GearHd6 is offline
Vehicle: 2010 Ram 1500 CC
Color: Mineral Gray
GearHd6 is on a distinguished road
I towed a 4800lbs travel trailer and the highest I saw the trans temp was 155 degrees.
Old 05-08-2013, 02:27 PM
jj ram's Avatar
jj ram jj ram is offline
Vehicle: 2014 Dodge Ram 4x4
Trim Level: Outdoorsman
Color: Maximum Steel Metallic
Rep:16
jj ram is on a distinguished road
It will depend on how much your are towing, your gear ratio, and how much your transmission is "hunting" for the right gear, road terrain, outside temp etc..
To give you an idea, I tow a travel trailer around 6500 lbs, with a 3:55 gear ratio, highest trans temp I've recorded was 96 c (204 f) that was on a very hot day and in 5th in the tow mode. If I drop it to 4th in the tow mode, there is less gear hunting and temps stays below 70 c (158 f).
I believe anything over 230 f will start to break down your oil and anything over 275 is the danger zone when you start to get warning lights and tranny breakdown...
"They will not force us, they will stop degrading use, they will not control us, we will be victorious" - Muse
Old 05-08-2013, 10:01 PM
maximus007's Avatar
Rep:12
thanks jjram just what i was looking for i have the same exact setup and trailer weight and thats the hottest ive had mine also.
