wheel question - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 05-06-2013, 10:12 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
he has a good point ^^^^^
a wider wheel can bulge the sidewalk some more but u can only stretch the actual tread so much. no doubt a wider wheel will affect the width some, but maybe not as much as you think
Someone else with a little knowledge yeah!?
Technically the c.s. of the tire is the widest point of the sidewall.
That c.s. is determined by the steel belts. With that said, wider wheels don't effect dick. Unless of course it's a bias ply and I don't think any of these pavement pounders run bias plys haha
Originally Posted by gbarkley View Post
i read that i can use a 8-10" wide wheel for the 12.5 wide tire....im new at this
You sure can. I ran 35x12.50 Federal Mts on my wife's JK Rubicon stock 7" wide wheels. I'm also running a 38x15.50 wide Nitto Mud Traps on 10" wide wheels on my Ram.
[CENTER][SIGPIC][/SIGPIC]
Old 05-06-2013, 10:15 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
learn from the best ^^^^
Old 05-06-2013, 10:24 PM
gbarkley's Avatar
gbarkley gbarkley is offline
Vehicle: 2004 Dodge Ram
gbarkley is on a distinguished road
ok. so im ok on the width now. and im looking for a -12 offset? what about backspacing?
Old 05-06-2013, 10:26 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Offset and backspacing are directly related. Offset is how far off center the mounting surface off the wheel is. A -12 offset on a 9" wide rim is 4.5" backspacing. -12 offset on a 10" wide rim is 5" backspacing.
Old 05-06-2013, 10:41 PM
candy08's Avatar
Rep:213
^^^ exactly right
So why is everyone saying that a 10" wheel with 4.5" bs will stick out an inch farther than a 9" wheel with 4.5" bs. If 4.5" of bs is 4.5" bs across the board and a radial c.s. doesnt change, where does the extra inch come in...
Mind officially blown
Old 05-06-2013, 10:48 PM
candy08's Avatar
Rep:213
Tryin to get in these britches again I see
Wait wut
Old 05-06-2013, 10:50 PM
Rep:1900
here we go again. Hahahaha
but ya whoever was asking, take it from the guys above. they know their stuff, esp candy.
Old 05-06-2013, 11:17 PM
jake09's Avatar
jake09 jake09 is offline
Rep:56
jake09 will become famous soon enough
For every .5" change in wheel width, the tire width will increase or decrease about .2"
If you had 9" wheel with 4.5" bs and a 10" wheel with 4.5" bs and just mounted the wheels with no tires, the 10" wheel will stick out 1" more. But once you add tires, the tires on the 10" wheel will only stick out about .2" more bc it will stretch the overall width out about .5" (quarter inch on both sides)
Also for people that are always so confused on backspacing lol here you go
[IMG]http://www.**************/members/dginter-74919/albums/offset-backspace/41174-tech-wheeloffset.gif[/IMG]
2009 Ram 1500 4x4
6" superlift, 1.25" bl, 37 nitto mg's, & too much to list..
Old 05-06-2013, 11:37 PM
candy08's Avatar
Rep:213
If that's true then why do you need .5" or 13mm of offset to get the same backspacing. If it sticks out an inch farther, then the offset would remain the same to obtain the same backspacing right?
Matter of fact look at your chart you just posted. If you go from 9 to a 10 you need 13mm of offset to get the same bs. Going from a 9" to 10" can ONLY stick out 13mm/.5" farther, not an inch. Unless you know sorciery or magic there Jake...
Also the sidewal doesn't stretch. The inner most part of the sidewall, sure. But the actual width of the sidewall or c.s. never changes...specially going from 9 to a 10. Now to a 14" on a 12.50 it would if it would hold lol.
Old 05-06-2013, 11:56 PM
jake09's Avatar
Rep:56
candy08 If that's true then why do you need .5" or 13mm of offset to get the same backspacing. If it sticks out an inch farther, then the offset would remain the same to obtain the same backspacing right?
Haha what?!? confused on this
Backspacing is distance from inner lip to the mounting face of the wheel..if you mount 2 wheels with the same backspacing but one is 1" wider it will stick out 1 more inch (with no tires mounted) Like 4.5" from inner lip to mounting lip then it will be 4.5" more to outside lip of a 9" and 5.5 " more to the outside lip of a 10" wheel..that's why a 10" wheel with the same backspacing of a 9" wheel will have a deeper dish b/c it extends out further
And yeh the side wall won't stretch but near the wheel lip it will..If you run wide ass tires on skinny wheels the tread will balloon up some too wearing the middle of the tires down quicker unless you air down a shit load. The width of the tires just isn't noticeable going from 1" wider or narrower wheel bc its changes so slightly..I'm pretty sure a 12.50 will be wider on a 14" wheel than on a 7" wheel. But haven't done it lol
Wider wheels can't stretch/bulge sidewalls?? hmmm haha
2009 Ram 1500 4x4
