Old 05-06-2013, 09:48 PM
BCRAM BCRAM is offline
Vehicle: 2012 RAM 1500 QC 4x4
BCRAM is on a distinguished road
Default 20"tires - 17"spare?
I was crawling under my truck today and noticed that the spare tire is 17" whereas the truck has factory 20" tires.
The question I have: Is the correct? I know that many vehicles come with a smaller/compact spare and normally would not think 2x about using it. However my truck has a limited slip rear end and I would be very hesitant to out a smaller diameter tire on as I would be worried about damage to the LS due to the tire size difference.
That said, due to the factory trailer hitch, there is not much room if any for a bigger tire under there as it looks like the tire would not fit...
Are my concerns justified?
Old 05-06-2013, 09:52 PM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
The rim diameter is irrelevant, it's the tire's diameter that matters. Your spare is relatively close in diameter to your 20's, and LSD's are forgiving enough for minor differences anyway. It's not like you have a locker or spool. You are completely safe to run your spare.
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
Old 05-06-2013, 09:59 PM
Thanks, I knew about the rim size and should of mentioned that I was concerned about the tire diameter.
Good to know though as I am planning a month long trip which will be into some remote locations, population wise and I did not want to be stuck if the tire diameter was a major concern.
Old 05-06-2013, 10:16 PM
pappy10's Avatar
pappy10 pappy10 is offline
Vehicle: 2008 Dodge Ram
pappy10 is on a distinguished road
I also have 20" and a 17" spare when I cranked it down and put it beside my wheels on the truck it was the same height. I have 50 series tires on the truck and the spare i think is 85series (huge looking tire)
