Old 05-06-2013, 11:35 PM
2012ramsportellis's Avatar
2012ramsportellis 2012ramsportellis is offline
Vehicle: 2015 dodge powerwagon
Trim Level: power wagon
Color: blue streak pearl coat
Rep:94
2012ramsportellis will become famous soon enough
Default Bilsteins at 1.4" setting , what have you exerienced ?
Jus looking for some other thoughts on you ram 4g 1500 with bilsteins set at 1.4". shutters , vibrations in 2wd and 4wd.
I recently had a 6" rcx lift installed on my 2012 ram sport 1500 , along with bilsteins set at the 1.4" setting and I have a bad shutter from 0-25 km/hr in 2wd and worse in 4wd , the truck has been back to the shop that installed the lift kit twice , everything was checked over no issues were found , all u joints were exc since my truck only has just over 8000kms . I am considering lowering the bils down to 0 or .7 setting to correct this issue .
RCX 6" RCX 1.25" bl Bilsteins at 1.4 Mufflex 18" go-rhino dominator 2 side steps
Old 05-06-2013, 11:44 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
Deliciousness...
[CENTER][SIGPIC][/SIGPIC]
Old 05-06-2013, 11:45 PM
05cr125r's Avatar
05cr125r 05cr125r is offline
Vehicle: 2012 Big Horn QC
Trim Level: Big Horn 4x4
Rep:94
i haven't heard of many guys setting that low...mine are at 2.1...no problems and better
Mods; Line X, Bilsteins set at 2.1, Magnaflow 18", Debadged , Cool White LED Interior, LED license plate, Cool White LED reverse, Fronts tinted 20 %, Stubby Antenna,AVS WindowVisors, Black Honeycomb Grille Insert, Green Performance Air Filter, SuperChips Flashpaq 3482
Old 05-06-2013, 11:48 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
you should be fine bubba
Old 05-07-2013, 12:00 AM
candy08's Avatar
Rep:213
I see you edited. It's that cheap lift lol. That shutter is a common issue with a 12. Do you have the redesigned diff bracket? Go look at your front pinion angle. Either way I would contact Mitch at RCX bc he is aware of this issue. Tell him what ur experiencing and he'll get it to you ASAP.
Either way you're running 2.5" worth of levelin kit. You cant get aftermarket cvs for your truck yet....I don't think. I would lower it and go from there.
Old 05-07-2013, 12:07 AM
Rep:94
The kit I had installed was the 324s for the 2012 . is there a newer updated diff bracket out ?
Old 05-07-2013, 12:11 AM
Rep:94
Default few pics
Old 05-07-2013, 12:13 AM
candy08's Avatar
Rep:213
You've got the old brackets It looks like, bet that's ur issue. Hang on I'll get you some pcs so you can go check which one u got.
Old 05-07-2013, 12:19 AM
candy08's Avatar
Rep:213
Yours like this, before bracket...
After new brackets
Old 05-07-2013, 12:23 AM
Rep:94
After new brackets
holy fack what a difference ! I will compare these pics to the ones installed on my truck tmr . so how recent have they changed these brackets ? I ordered the 324s kit so I would not have this issue ..?
