Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Drive Line
Drive Line Ball Joints - Wheel Bearings - Shocks - Springs - Alignment etc.
Old 05-07-2013, 10:29 AM
hunter416's Avatar
hunter416 hunter416 is offline
Vehicle: 2007 Dodge Ram 2500
Color: Gray
hunter416 is on a distinguished road
Default Vibration
I have a 2007 Dodge Ram 2500 Quad Cab. It has a small vibration. My mechanic has checked all the u-joints in the front end and the drive shaft and they are a all good. It has all new wheels and tires. The ball joints are good. The vibration is not in the steering. Any ideas?
Old 05-07-2013, 10:31 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
When did the vibration start? before or after new wheels/tires
aftermarket wheels?
you said not in the steering so I'd assume not tie rods or anything. Those can sometimes be a cuplrit.
And welcome to the forum. Be sure to stop by the newbie section and introduce yourself!
Old 05-07-2013, 12:02 PM
Ramageddon's Avatar
Ramageddon Ramageddon is offline
Vehicle: 2012 Dodge Ram
Color: Mineral gray
Rep:37
Ramageddon is on a distinguished road
I had a similar problem when I had my 2005 1500. I changed the driveshaft, tie rods, brake rotors and had the tires balanced three times, once on the hunter road force balance machine. I never found it or got rid of it. I suspect if you just got new tires and wheels and it just started theres a good chance thats your culprit. Also the tires may balance correctly but one could be defective. A road force balancing should determine that. Good luck I hope you find it.
