Rear Differential Oil Question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Drive Line
Drive Line Ball Joints - Wheel Bearings - Shocks - Springs - Alignment etc.
Old 07-22-2015, 09:51 PM
mace of bass mace of bass is offline
Vehicle: 2011 Dodge Ram
mace of bass is on a distinguished road
Default Rear Differential Oil Question
Hey guys, I have a question regarding Differential oil change.
I have a 2011 Ram 1500 2wd with a 3.55 ZF LSD axle. I have a drain plug on the lower right and a fill plug in the upper part of the differential in front of the axle. I started the job by removing the fill plug first, and when I did, I had quite a bit of oil come pouring out on me. I know there was an issue with these axles with the fill plug being too low, but my truck was built in july 2011 after the recall. I assume the issue was resolved.
Anyway, I only got 2 quarts of oil in plus the 4 oz of LSD additive before oil came pouring out of the hole. Am I good, or do I need to add some in from the vent hose?
Old 07-23-2015, 08:46 AM
Rep:1915
Total refill for your axle is 4.4 pints of 75W-140, including the LSD additive. You're fine as is.
Old 07-23-2015, 08:51 PM
Thanks Ram!! No noises after driving back and fourth to work so all seems well.
