Old 05-07-2013, 12:10 PM
EWC88 EWC88 is offline
Vehicle: 2002 Dodge Ram 1500
Rep:25
EWC88 is on a distinguished road
Default Level kit or drop shackles?
Looking at either doing a level kit or drop shackles for my 02 2wd 1500. Wondering what is pros/ cons of both and what do you recommend? Will probably lift truck in future.
Old 05-07-2013, 01:34 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
if you are planning on lifting...why would you drop?
You can just adjust the torsion bars (safely) up to 2-2.5" MAX and level it...for free. Then lift when you are ready
Old 05-07-2013, 01:40 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2032
Doesn't make sense to drop it now if you're going to lift it later. Just crank the torsion bars up a bit. But as gonefishin776 said, no more than 2-2.5"
Old 05-07-2013, 02:05 PM
Rep:25
Yea didn't even think of that. Is there any issues with cracking torsion bars to lift it? Any of you guys do this before?
Old 05-07-2013, 02:08 PM
Rep:1900
A number of guys on here do it. You just have to in moderation. Don't go max them out..it'll be bad on your suspension components. many guys run at 2" or so and no problems
Old 05-07-2013, 02:10 PM
Rep:2032
Nope, never had any problems with cracking torsion bars on any vehicle. Never heard of that problem either.... My dad's 1970 Dodge Dart has torsion bars. When it comes down from a wheelie at the track the torsion bars are fine. Just to give you an idea of how strong they are.
I've cranked the torsion bars on both my dad's and brothers chevy 1500's. Took about 4-5 full turns of the bolt that pushes the key up to get it level (or at least level to the eye, still has about 1/2"-3/4" rake).
Old 05-07-2013, 03:57 PM
Rep:25
You can do with a 2wd? I heard you can't and only 4x4.
Old 05-07-2013, 04:21 PM
Rep:1900
oh I over looked 2wd :/ not sure about that. sorry mannn
Old 05-07-2013, 06:42 PM
tclark's Avatar
tclark tclark is offline
Vehicle: 2009 Dodge Ram QC
Color: Deepwater Pearl
tclark is on a distinguished road
Just leveled my 09 2wd with a level kit which is a spacer that goes on top of the front coil spring. Looked it up real quick and it shows the same part #.
http://www.autoanything.com/suspensi...A5217A0A0.aspx
