Old 05-07-2013, 02:59 PM
beast88 beast88 is offline
Vehicle: 2013 Dodge Ram
beast88 is on a distinguished road
Default Bilsteins set at 2.1 or 2.8?
Just got done ordering my bilstien shocks. Wondering if most of you guys running them have them set at 2.1 or 2.8 and why
Thanks
Old 05-07-2013, 03:17 PM
nfd538's Avatar
nfd538 nfd538 is offline
Vehicle: 2012 sport crew
Trim Level: sport crew
Rep:16
nfd538 is on a distinguished road
When I find time to install mine I'll be using the 2.1 setting. Why you ask? From what I've seen the 2.1 height looks best.
BT catch can, 20% tint, Leer 100xl top, Aero 3030xl
Bilstein 5100, Duratracs 275x65x20 (winter), 20" SRT & 275x55x20 Nitto terra graps (summer), InTune DCX, MagHytech diff coverhttp://i29.photobucket.com/albums/c2...pstcriuhl7.jpg
Old 05-07-2013, 03:24 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
I have to agree. There are some guys with them maxed that are happy with them but I personally think 2.1 looks best. I have seen a few set at max that appeared to be nose high. Not to mention, 2.1 will put less stress on your front end components and is less likely to cause vibration, steering, or alignment issues.
Old 05-07-2013, 03:25 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2032
Partially depends on what size tires you plan on running too. If you want to run full 35's I think you need them at 2.8".
At 2.8" it will probably sit dead level or slightly nose high so you'll want to add a rear coil spacer as well. They are pretty cheap from Top Gun Customz. But it is another cost....
Old 05-07-2013, 10:36 PM
Ian Campbell's Avatar
Ian Campbell Ian Campbell is offline
Vehicle: 09 Dodge Ram Sport Rambox 4x4
Trim Level: Sport crewcab Rambox
Color: brilliant black
Rep:15
Ian Campbell is on a distinguished road
I have mine set at 2.1 and my front sets up about an 1/2 in the front. Im thinking of getting a 3/4 spacer for the rear, and see how it turns out. I know some guys have theres set at 2.8 and say there truck is level, but im not sure why mine sets like it does at 2.1.
Old 05-08-2013, 01:32 PM
Do you have to take them completly out to change the setting?
Old 05-08-2013, 02:12 PM
Rep:367
Yes, they must be completely removed and the spring compressed again to change the setting.
