Old 05-07-2013, 10:58 PM
rjmlakota's Avatar
rjmlakota rjmlakota is offline
Trim Level: Sport Crew Cab
Color: Mineral Gray Metallic
Rep:18
rjmlakota is on a distinguished road
Default 35 12.5 tires on stock rims
I have searched on here and found a few threads stating 35/12.5 tires will fit on the stock rims and not rub. Can anyone confirm this?? I'm about to pull the trigger on a set of Toyo Open Country A/T's and want to be SURE they will fit on the stock rims without a leveling kit. I'm planning on getting a leveling kit, but I'm a few months out from getting the leveling kit.
Also, how much will my speedo change with 35s?
Thanks in advance,
RJ
Old 05-07-2013, 11:42 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2051
They won't fit without a leveling kit and 1/4" spacers. You need BOTH before you can put those tires on your stock rims.
Your speedo will be out about 5-6%
Old 05-08-2013, 02:13 AM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:67
The speedo reprogram depends on your dealer. The dealer that replaced my 8.4a did mine for free while it was there. Best thing is if you go in for a oil chance ask then. Usually if your having them so something else at the same time they will cut you a deal in the price to earn you business. I was going to install a factory remote start and I have gotten prices for the flash from $25 from a dealer wanting I to get my service work to $100 from one that just wanted to make $$. There are a few in between that I got.
Old 05-08-2013, 10:39 AM
nfd538's Avatar
nfd538 nfd538 is offline
Vehicle: 2012 sport crew
Trim Level: sport crew
Rep:16
nfd538 is on a distinguished road
Op, if you don't follow this before you order those tires you'll be screwed. A 12.50 wide tire needs a spacer to fit on stock wheels.
BT catch can, 20% tint, Leer 100xl top, Aero 3030xl
Bilstein 5100, Duratracs 275x65x20 (winter), 20" SRT & 275x55x20 Nitto terra graps (summer), InTune DCX, MagHytech diff coverhttp://i29.photobucket.com/albums/c2...pstcriuhl7.jpg
Old 05-08-2013, 12:31 PM
rjmlakota's Avatar
Rep:18
Thanks for the quick responses! I've tried finding comparisons on line but have been unsuccessful. Does anyone have pictures if a truck running stock tires and another one running 35's? Is there much of a difference visually?
I'm thinking of just staying with the stock tire size.
Old 05-08-2013, 12:52 PM
nfd538's Avatar
Rep:16
Fella here username blkbaretta has a HBS 2.5" level with a RCX 1.25" body lift on stock 20's. he also shows same lift with aftermarket wheels and tires.
I'm kind of in the same boat as you. I just got Bilstein leveling shocks and probably will run the stock wheel/tires for awhile with level set to 2.1"
Old 05-08-2013, 02:59 PM
Rep:2051
There's a huge difference. Not only because of the height of the tire but because of the width and aggressive look of them as well.
Here are a few good threads to look at with comparrison pictures. Yes there are tons... but you should find what you're looking for.
http://www.ramforumz.com/showthread.php?t=90657
http://www.ramforumz.com/showthread.php?t=70555
Here's my thread which has a comparrison picture between my stock wheels and tires (17's) and my 35's.
http://www.ramforumz.com/showthread.php?t=141365
Old 05-08-2013, 10:03 PM
rjmlakota's Avatar
Rep:18
Brandon,
That's EXACTLY what I was looking for!
Thanks!
