Old 05-08-2013, 02:36 AM
Twinkeys0816's Avatar
Twinkeys0816 Twinkeys0816 is offline
Vehicle: 2006 Dodge Ram 1500
Twinkeys0816 is on a distinguished road
Default upper ball joint replacement
hi guys! im planning on replacing the upper ball joint. ive got a 2006 ram 1500 4.7l v8 4x4. do i need to replace the upper control arm thats with the ball joint or can i just replace the upper ball joint alone.
Old 05-08-2013, 06:45 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
did a quick search on google, and the general consensus is you have to replace the whole assembly (balljoint/UCA).
but then i just now read another post saying they replaced just the ball joints it seems. But that also appears to be way more difficult to press the ball joints in/out so if you can afford it, just do the assembly I guess.
Good luck and I hope this helps some.
BUMP for someone with more info
Old 05-10-2013, 11:48 AM
bparsel bparsel is offline
Vehicle: 2014 Ram
Rep:25
bparsel is on a distinguished road
I just did my uppers. The factory manual has them listed as being unserviceable and to replace the whole assembly. I chose not to believe that and went ahead and ordered the ball joints and got the press tool from O'reillys. After spending some time trying to press them out I gave up and replaced the entire assembly with MOOG Upper Control Arms and was done with it.
Order the whole asembly from Rock Auto and it isnt that expensive. The MOOG replacements ARE serviceable for any future Ball Joint replacements.
Old 05-14-2013, 09:51 AM
SI Integra SI Integra is offline
Vehicle: 03 Ram
Trim Level: SLT Sport
SI Integra is on a distinguished road
You can press them in, but it is not worth the difference in time or money and the availability of ball joints are slim at best. Bparsel hit it right on, buy the Moog and be done with it.
Old 05-16-2013, 01:40 AM
thank you for your input guys, much appreciated. i will definitely get the whole assembly.
Old 04-02-2015, 02:33 PM
Gniccum Gniccum is offline
Vehicle: 2010 Dodge Ram 1500 HEMI 4x4
Color: Metallic silver
Rep:21
Gniccum is on a distinguished road
Sorry to bring up an old post, but what was the part number? I can't seem to decide on which CA assembly to buy. I'm on rock auto
Old 04-02-2015, 07:18 PM
Muddking Muddking is offline
Vehicle: 2005 Dodge 1500 QC
Muddking is on a distinguished road
Good luck trying to get some one to answer your question on this forum. This is what i use to find my part numbers for anything that has wheels.. http://www.fme-cat.com/application.aspx
