Old 05-08-2013, 03:42 AM
Twinkeys0816's Avatar
Twinkeys0816 Twinkeys0816 is offline
Vehicle: 2006 Dodge Ram 1500
Twinkeys0816 is on a distinguished road
Default exhaust manifold fix
so im thinking of getting the exhaust manifold fix. i went under there and found out that a stud is missing, im guessing its broken also found that the gasket is bad cause theres black stains around the manifold. i just wanna get a heads up from you guys on how much would the cost be for a repair like this or what would you recommend me do before i take it to the shop. im thinking if im getting this side done might as well do the other side? would be nice not to hear that ticking sound anymore.
Old 05-08-2013, 06:14 AM
Chris65 Chris65 is offline
Vehicle: 2007 Dodge Ram
Color: silver
Rep:45
Chris65 is on a distinguished road
It needs at least a new stud. A shop can drill it out and install a new one. The manifold needs to be checjed if its still straight. If not, you need a new one.
There is no need to replace the other nanifold, too.
If they removed the manifold anyway, they should replace all bolts. Don't worry-let coolant run over and wait an hour. They come out very creamy. Better than with wd40.
How much it cost? Don't know.
Old 05-18-2013, 05:11 PM
hotrod69 hotrod69 is offline
Vehicle: 2004 Ram
Trim Level: 1500
Color: blue
hotrod69 is on a distinguished road
Its better to do it yourself. I just drilled and tapped 3 holes that had broken bolts n it. Took about 4 hours to tear down and put back together. I usually charge at my shop about half hour labor for each broken bolt plus the labor for r&r of manifold. Depending on shop u go to and there rates ur looking at 2 to 300 dollars plus parts for repair.
