Vibration problem - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 05-08-2013, 07:44 AM
hunter416's Avatar
hunter416 hunter416 is offline
Vehicle: 2007 Dodge Ram 2500
Color: Gray
hunter416 is on a distinguished road
Default Vibration problem
I have a 2007 Dodge Ram 2500 Quad Cab. It has a small vibration that feels like its in the rear at times and in the front at other times. My mechanic has checked all the u-joints in the front end and the drive shaft and they are a all good. It has all new wheels and tires. The ball joints are good. The vibration is not in the steering. Any ideas?
Old 05-08-2013, 07:46 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
you posted this question before in a different section and two of us answered. Did you see it?
Old 05-08-2013, 08:00 AM
hunter416's Avatar
Color: Gray
No. The only thing I saw was welcome messages. Sorry
Old 05-08-2013, 08:01 AM
Rep:1900
It's okay! The site can take some getting used to. Just click your user name in the upper right hands corner, then click "statistics" then click "view all threads by hunter416" there you can find your old post
Old 05-08-2013, 08:17 AM
hunter416's Avatar
Color: Gray
Thanks! In your reply you asked if the vibration was there before the new wheels and it was. The vibration was there before and I was told one of the old wheels had bend in it that was causing the vibration. I put a set of American Racing wheels on it and a set on Hankook tires on but the vibration is still there. At times it feels like its in the rear end and sometimes it feels like it's in the front. My mechanic has drove it and says he doesn't think it feels like it's in the steering nor do I. I'm at a loss.
Old 05-08-2013, 08:27 AM
Rep:1900
Does the vibration now seem DIFFERENT in any way than the vibration before the wheels/tires?
Possibility: there was a vibration caused by the bent wheel. Now that's gone...but a new vibration due to new wheels. Common with aftermarket wheels, they usually are no longer hub-centric (centered by the hub) and are only lug-centric now. Aftermarket wheel companys will make the inner bore of the wheel larger so that it can be used on more vehicles. So what happens is your wheel can be slightly off center and cause a "vibration" while at speed. I am currently experiencing this with my new wheels. Every time I take my wheels off to do maintenance and put them back on, the vibration is coming from a new spot. Because sometimes I luck out and the wheel snugs up centered, and sometimes it doesn't.
Old 05-08-2013, 09:52 AM
hunter416's Avatar
Color: Gray
The wheels are ATX series 185 Crawl by American Racing and I don't believe they are hub centric (But dang they look good!), so that would probably explain the varying vibrations in the front and rear.
Old 06-05-2013, 11:23 AM
hunter416's Avatar
Color: Gray
Default Repairs
New ball joints, lowered the air pressure in the new tires, and replaced a badly warped rotor and a very worn out caliper on the drivers side. Keeping my fingers crossed. I will let you know after I test it.
Old 06-05-2013, 11:31 AM
Rep:1900
good luck man! hopefully the issue is resolved
Old 06-05-2013, 03:53 PM
hunter416's Avatar
Color: Gray
Worked pretty well. All most all of the vibration eliminated, except for a slight bit and I believe that is left because the new wheels are not hub centric.
