United Radio
Old 05-08-2013, 01:13 PM
ejmram2011 ejmram2011 is offline
Vehicle: 2011 Dodge Ram 1500 Big Horn
ejmram2011 is on a distinguished road
Default 35" tires on stock 20" rims.
I'm sure this question has been brought up a lot but i can't seem to find an exact answer. I have a 2011 Ram 1500. I put a Rough Country 2.5" leveling kit and 1.25" body lift kit on. I would like to put 35's on but I want to keep the [COLOR=blue !important][COLOR=blue !important]stock[/COLOR][/COLOR] rims due to the fact that i like how they look and simply cant afford tires AND rims. I am told that due to the rim's off set the 35's will rub suspension parts. Is this true? and if so, will spacers solve the problem?
Old 05-08-2013, 01:36 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Yes, you will need 1/4" spacers to clear 35's on the stock wheels.
Old 05-08-2013, 05:10 PM
Any recommendations on spacers?
Old 05-08-2013, 05:23 PM
11bighorn's Avatar
11bighorn 11bighorn is offline
Vehicle: 2011 dodge ram
Trim Level: big horn
11bighorn is on a distinguished road
Rough country sells 1/4 inch spacers...
do you have any pics of the truck with the 2.5" leveling kit and 1.25" body lift kit? I have the 2.5 inch level on mine already and was thinking about doing the 1.25 body lift too
Old 05-08-2013, 07:35 PM
Grubrunner's Avatar
Rep:3883
What 35" tires are you looking at?
Grub out!
Old 05-09-2013, 04:05 PM
@11bighorn Thanks Ill check out rough country's spacers. I don't have any pictures yet. I have only installed the leveling kit so far. The body lift is still in the box becuase I wanted to see how the truck will look with the 35's before I installed the body lift.
@grubrunner I'm looking at the Nitto Trail Grappler M/T's. Any other recommendations?
Old 05-09-2013, 04:55 PM
Rep:2026
The Toyo Open Country MT's are another option, very comparable to the Nittos. Nitto is owned by Toyo so they are essentially the same company. Here's a link to my first impression review of them on my truck:
http://www.ramforumz.com/showthread.php?t=141365
If you want to go a little bit cheaper Federal Couragia MT's is another option. Quite a few guys are running them now with no complaints. But they do measure smaller than the other 35x12.5 tires.
Fuel just started making their own MT's as well. Haven't really heard much about them yet but they do look very sick. I think the price point is around the same as the Nitto Trail Graps or the Toyo MT's.
Old 05-12-2013, 01:36 PM
nfd538's Avatar
nfd538 nfd538 is offline
Vehicle: 2012 sport crew
Trim Level: sport crew
Rep:13
nfd538 is on a distinguished road
Motorsport-tech.com, probably the best spacers you can get.
BT catch can, 20% tint, Leer 100xl top, Aero 3030xl
Bilstein 5100, Duratracs 275x65x20 (winter), 20" SRT & 275x55x20 Nitto terra graps (summer), InTune DCX, MagHytech diff cover
Old 05-12-2013, 04:01 PM
hemipowerv8 hemipowerv8 is offline
Vehicle: 2013 Ram Sport CC 4x4
Rep:74
hemipowerv8 will become famous soon enough
I ordered a set from them a couple weeks ago. Should be in this week. The owner said they are a bit over 1/4" thick because I requested wheel and hub centric. About 3/8" he said.
Mods: Tint, Line-X spray in, PD emblems, Weathertech mats, Honeycomb grille, Mopar tow hooks, Magnaflow 18" and Y, Bilstein 5100s @ 2.1" & TGC rear spacer .75", Toyo All terrains 35x12.50x20, 5" black tips, BakFlip tonneau cover, 87mm tb
Next: Gorilla lifetime lug nuts, CAI, Diablo tune.
Old 05-12-2013, 10:01 PM
NWRQC's Avatar
NWRQC NWRQC is online now
Vehicle: 2007 RAM
Rep:64
I'm not sure that I would feel comfortable running those with OEM studs. A 1/4" is about the max I would run while still getting enough bite from the lug nuts. I'm surprised that nothing was mentioned to you about that..
Also I'm not sure what having a hub centric bore has to do with thickness. The only change is the bore diameter. I curious to know why a 1/4" spacer would need to be 3/8th of an inch in order to be hub centric.
2007 6.7| EFI-Live | ARP | T4 S366 | AFE | Draconian tuned TCM
