Old 05-09-2013, 10:21 AM
rexmobile rexmobile is offline
Vehicle: 2013 Ram 1500 4x4 CC Sport
Trim Level: 1500 Sport 4x4 CC
Rep:35
rexmobile is on a distinguished road
Default Can I fit 35x12.5's on 20x9 wheel with 0mm/5"?
Hi all. Looking to get new wheels/tires for my '13 Sport 4x4 CC. The wheels I am looking for are 20x9" with 0mm offset/5" backspacing. I want to put 35x12.5 tires on. Will they fit on these wheels?
Thanks!
Old 05-09-2013, 10:26 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
yes they will fit on those wheels.
but, are you leveled? if not you won't clear those 35x12.5 tires
Old 05-09-2013, 10:36 AM
Rep:35
Thanks, no I am not leveled, yet.
I plan on going with the 20x9 wheels first, with 275/65/20 Duratrac's, at STOCK height.
I still can't decide if I want to LEVEL my truck, or lift it 2 or 4". That's when I will swap out the tires and put on the 35x12.5's.
Old 05-09-2013, 10:39 AM
Rep:1900
gotcha. sounds like a plan.
my personal opinion, go 4" with a lift kit. 2" would just be leveling it with maybe some spacers in the rear.
4" with those 35s will look great! be sure to post pics!
Old 05-09-2013, 02:41 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2036
Exactly what gonefishin776 said. 2" lift is essentially a small leveling kit. I have a 2.5" and guys running Bilsteins maxed are technically 2.8". If you want to get some actually height on it I'd look into the Zone 4" lift kit of the 6" Rough Country lift kit. And I'd honestly recommend going for the 6" over the 4". The 6" Rough Country kit is a similar cost to the 4" Zone kit and you'll probably end up regretting not going 2" higher down the road. And IMO 35's look fine with a 6" lift.
Rough Country does make a 4" kit as well that is a little bit cheaper, but what I don't like about it is that it uses coil spacers in the back rather than lift springs like the Zone kit. a 3" coil spacers is pretty half assed IMO. And again, the Rough Country 6" kit is only $150 more than the 4" kit. But through Discount Auto Performance you could get an even better deal!
