Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 05-16-2013, 01:12 PM
WyoUltra WyoUltra is offline
Vehicle: 1998 Dodge Ram 1500
Color: Pewter
WyoUltra is on a distinguished road
Ok so I tried a wire going off of the coil connection, nothing happened (did I check correctly?) Also the boot looked clean, I also tried putting a wire into the plug boot off of the coil that goes into the dist. cap, nothing. However the plug wire looked clean. Should I take my coil to autozone and have them test it??
Old 05-16-2013, 02:59 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Yessir, that's what I'd do.
Old 05-17-2013, 03:16 PM
Color: Pewter
Autozone claims they cant test it... Shouldn't I be able to just hook it up to a volt meter and do an ohm test on it?
Old 05-17-2013, 05:00 PM
Vehicle: 95
Rep:1776
Test to make sure you have power going into it with the key on.
If you have power going in and nothing coming out...
Old 05-17-2013, 05:35 PM
Color: Pewter
I tested it with a multimeter. The low resistance ohms were a high, supposed to be between 0.97-1.18 ohms, it was at 3.xx. Bought a new one, put it in, started third try, ran rough for a second, then idled just fine. I'm thinking this is because I tried starting it earlier it had no spark, and it just had to clear up the extra fuel. Does that sound right?
Old 05-17-2013, 06:12 PM
Vehicle: 95
Rep:1776
Maybe some extra fuel especially from the starting fluid etc, and the earlier trying.
How much was the new coil? I was thinking around $16.
Old 05-17-2013, 07:05 PM
Color: Pewter
Ha... $38.84 with tax, and a limited lifetime warranty.
Old 05-20-2013, 12:04 AM
Color: Pewter
Well.. My check engine light came on today, tried the self check method, nothing came up. Took it in to O' Reily's (close by) plugged it in, nothing came up, tried replugging it in, still nothing. The light then went out. The guy went inside, jumped back in my truck tried to start, turns over, nothing. Tried again, started right up, check engine light came back on. Also while we were sitting in front of O' Reily's my fuel light came on, (gauge was reading a little over half when we pulled in, but I did park on an incline in front of the store.) Is my sending unit going out????
Old 05-20-2013, 10:00 AM
Vehicle: 95
Rep:1776
Low fuel pressure or a failing pump could add to your complications.
Old 05-20-2013, 10:22 AM
Color: Pewter
How do I check the fuel pressure?
