Back up camera stopped working! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 05-09-2013, 10:04 PM
TBILLIOT's Avatar
TBILLIOT TBILLIOT is offline
Vehicle: 2011 dodge ram 1500 quad cab
Trim Level: sport 4x4
Color: hunter green pearl
TBILLIOT is on a distinguished road
Default Back up camera stopped working!
My back up camera does not show up anymore but the sensors still beep off,has this happened to anyone else and if so how did you fix it?
Old 05-12-2013, 12:05 PM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
Maybe try unplugging and replugging it? I think there is a spot that unplugs at the bottom of the tailgate on the inside. ( so that you could remove the tailgate.) Otherwise maybe it died. Should be covered under warranty.
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 05-12-2013, 09:35 PM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:86
topgun will become famous soon enough
Is the screen dark when you go into reverse? If not, then you may of inadvertently turned the camera off in the radio settings. If it is dark, then as mentioned above, you can check the tailgate plug.
The camera and backup sensors are 2 different systems so they have no effect on one another.
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Husky X-Act Contour Floor Mats, Cooper AT3 285/70/R17's, Moroso Catch Can
Old 05-14-2013, 08:06 PM
TBILLIOT's Avatar
It stays on whatever screen its on instead of going to the camera...i'll try to unplug it...as being covered under warranty,i have a lock pick on it so im pretty sure it wont be covered
Old 05-14-2013, 08:09 PM
TBILLIOT's Avatar
I can turn the back up camera on through my radio but when i put it in reverse it doesnt ingage...my cousin said his did the same thing but it started working again..mines been out around 2 weeks so far
