**DITCHED** the Ram 1500 - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 05-12-2013, 09:53 PM
tachel403's Avatar
tachel403 tachel403 is offline
Vehicle: 2011 Dodge Ram sport quad cab
Trim Level: sport
Color: blue
Rep:71
tachel403 will become famous soon enough
ah ok. yea im sure we could have figured out something else to do on Friday but glad to have friends that dont mind helping out.
Old 05-13-2013, 02:21 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"New Cummins here we go"
Trim Level: Longhorn Rambox
Rep:1648
WOW....Good thing that your ok........
Old 05-13-2013, 07:25 PM
tachel403's Avatar
Trim Level: sport
Color: blue
Rep:71
so took it in to get wheel alignment done and they couldnt get it within limits, it seems the camber is out on the right hand side. suppose to be 4 degrees. max they could get was 1.5 degrees so they came up with that the upper control arm must be bent. 280$ for part wanted 180$ to install it , i said ill do it myself. not paying 60$ a bolt(3 bolts to remove upper A arm). took 30 minutes for me to install. the one that they said was bent, wasnt noticeably bent at all but with it beign a matter of 3 degrees i dunno. now must bring back truck for another try at wheel alignment tomorrow.
Old 05-13-2013, 07:33 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
wow I can't believe the truck stayed on it's feet. I would have thought it would have went on it's side when you went off the road for sure. What exactly were you doing when it happened(texting, phone call, radio, etc)?
Unfortunately a lot of times things get "jarred" on impact. Hopefully you can get your suspension figured out and straightened out and have no real issues.
Sean
Old 05-13-2013, 07:52 PM
nfd538's Avatar
nfd538 nfd538 is offline
Vehicle: 2017 Ram 1500
Trim Level: Sport crew
Rep:16
nfd538 is on a distinguished road
Originally Posted by tachel403 View Post
yea a tow truck just hooked onto front a arm on right hand side and backed up and pulled me out.ot!
They pulled you out by the a-arm you are a lucky mofo.
2017 mods so far:
DeeZees tailgate assist, 20%tint, BT catch can, tinted tails
Old 05-13-2013, 07:58 PM
tachel403's Avatar
Trim Level: sport
Color: blue
Rep:71
no texting or anything just brain fart and wasn't watching road in front of me. and if this doesnt fix it then im thigking it may be the steering knuckle or the front cross member. cant see it beign the bottom a arm due to its cast and it would crack not bend
nfd538's Avatar
Rep:16
Well this is the follow up to my above post. Why in the hell would you allow a tow truck to yank you out by the a-arm. no front hooks then use the rear hitch. Never hook up to a suspension part or the axle for recovery.
2017 mods so far:
Old 05-13-2013, 07:59 PM
tachel403's Avatar
Trim Level: sport
Color: blue
Rep:71
there was nothing else they could hook onto and it didnt bend break or move anything i wasnt super stuck just need a tow out .
Old 05-13-2013, 08:08 PM
nfd538's Avatar
Rep:16
Do you have a rear hitch?? Have them pull you out the way you went in. That's just unnecessary damage that the tow guy isn't responsible for
2017 mods so far:
Old 05-13-2013, 10:35 PM
tachel403's Avatar
Trim Level: sport
Color: blue
Rep:71
the way the truck was if i was to pull it back out it would have either scratched the side of the truck or wreck the front bumper. it had to come out forwards, me and a few friends dug the whole front of the truck out and pretty much used the dirt to build a ramp so truck was in neutral and could have almost drove out just needed tow truck to pull little
