inconsistant loss of HP - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 05-10-2013, 11:24 PM
ez1990 ez1990 is offline
Vehicle: 1989 dodge d150
ez1990 is on a distinguished road
Default inconsistant loss of HP
I bought a 89' ram150 about 4 months ago. its equipped with a 318 TBI, and I am not unfamiliar with this engine because I've owned five before this one but none of them have given me the problems I am having now
Symptoms:
loss of power
excessive fuel consumption
anything more than half throttle and it misses, sputters, RPM jumps constantly, and anything more than 30MPH is impossible as for any kind of uphill grade
stalls when you stop or slow down
I've tried a new throttle positioning sensor (its currently new) and ive tried a alternate map sensor from my scrap pile but I don't know if its good or not.
and just to complicate the problem it only does this every now and then and does this without warning and whether its hot or cold does not matter
Old 05-13-2013, 09:47 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
Free bumppppppppppppppppppppppppppppp
Old 05-13-2013, 10:53 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Have you checked the cat converter. If the insides are loose they'll have a tendency to move around and block the exhaust blocking the back pressure.
Old 05-13-2013, 02:28 PM
crazzywolfie crazzywolfie is offline
Vehicle: 81 91 93 dodge
crazzywolfie is on a distinguished road
i would almost be tempted to check the sensor in the distributor? have you checked the computer to see if there is any codes?
91 & 81 d150 carburated 318's 93 R.C. F.I.318
Old 05-14-2013, 01:21 AM
not the converter its fairly new and yes ive checked codes ...it gives a map sensor code a clutch relay code (which it doesn't have but it shifts fine) and still a throttle position sensor code (even though it is new). one day when it was acting like this I just simply pulled over and quickly turned the key off then back on, and for about 15 miles it ran like new but then quickly started not taking fuel, misfiring at anything past half throttle but as long as your giving it about 1/4 throttle you cant tell it....also fuel economy is HORRIBLE when its like that
Old 05-14-2013, 01:22 AM
also I wasn't aware there was a sensor in the dist.
Old 05-14-2013, 08:16 AM
there is a Ignition Pickup in the distributor. to me it sounds like it might be starting to go bad.
Old 05-14-2013, 10:37 AM
oh yea I knew about those, I thought you meant camshaft position sensor or something
Old 05-14-2013, 09:54 PM
i think in 89 the pickup in the distributor also acted as the camshaft position sensor.
Old 05-14-2013, 10:18 PM
alright today I swapped the PCM out just to trouble shoot to see if that changed anything and all that I noticed was that now it seems sort of sluggish for some reason. but the only codes it reads now are 12,37 torque converter clutch solenoid circuit (which it does not even have a solenoid), and 21 problem with oxygen sensor signal circuit. sensor voltage to computer not fluctuating... so I will re-swap the computers tomorrow and see if it shows different but for some reason I've got in the back of my mind that it is the vehicle speed sensor idk why
