Old 05-11-2013, 09:30 AM
xtreme's Avatar
xtreme xtreme is offline
Color: Grey
Rep:29
xtreme is on a distinguished road
Default Collector Gaskets
Well I'm about ti install my lowering kit but was looking at the used BBK headers I picked up. I noticed that I do not have the collector gaskets or bolts. It appears to be a 3", but I cant seem to find a set that is for two mounting bolts. Where should I buy these gaskets and bolts? Links would be awesome. Also do you guys use any high temp RTV around the collector and manifold gasket? Thanks again guys. You all are a wealth of knowledge.
Old 05-11-2013, 11:44 AM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
You only need a set of Mopar factory gaskets at the manifold,
And high temp RTV at the collectors, might be a good idea to pick up new grade 8 hardware too. Header bolt kits available at summit/jegs etc...
Old 05-11-2013, 12:56 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
bolt lengths could be different than stock so you may want to measure...
