Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 05-11-2013, 12:19 PM
Lman Lman is offline
Vehicle: 2004 Dodge Ram Quad Cab
Lman is on a distinguished road
Default has anyone converted to an electric fan?
I have an 04 5.7 Hemi Ram and am starting to research an electric fan for my motor. just wondering if any of my Mopar brothers have done this. looking for fan size and such. She"s a quadcab so I"m just looking to ad a few easy ponys. Thanks
Old 05-11-2013, 03:57 PM
Vehicle: N/A
Rep:1045
lots do the convert with old Ford Taurus e-fans, hit up a junkyard and see what you can turn up.
Old 05-11-2013, 05:24 PM
Thank you for the idea. My brother in law is a Ford parts guru. many connections. Mopar to ya!
Old 05-11-2013, 05:28 PM
Vehicle: N/A
Rep:1045
no problem! let me know how it works out for you as I'm looking for a third Gen soon and Id love to run an e-fan
Old 05-12-2013, 05:14 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
Considered to be the most powerful electric fan you can use from either OEM or the aftermarket. It is a Ford 8C607 fan and is advertised as having 2500 CFM on low speed and 4500 CFM on high by most sources. It comes in the 90 to 95 Ford Taurus and Lincoln Mark VIII with the 3.8 litre engine. Is very popular with the Hot Rod and Muscle crowd as well as used in Offroad buggies etc.
The Mark VIII fan has 2 speeds - 3 wires. The outboard black lead (uppermost pin on the motor if you do not have the pigtail) is the ground (negative). The blue lead (lowermost pin on the motor) was used to activate the fan when the AC was turned on (positive). The center lead (also positive) is black. It was activated by engine temp. I understand that using the black/black combo will give you a higher fan speed than the black/blue combo.
3 Leads; 2 are positive (+) leads and 1 is a ground lead.
Lead functions in stock application:
-BLACK Outboard black lead is a GROUND.
+BLACK Center lead is a POSITIVE lead...actuates fan on engine temp.
+BLUE Outboard lead is a POSITIVE lead..actuates fan w/ aircon.
The Taurus fan is a 17" diameter fan and the MarkVIII is an 18" fan. They share the same motors, and the shrouds are different. The Taurus fan has an angled edge and the MarkVIII is a rectangle shroud.
MarkVIII
1993-96 #F3LY8C607A low speed 1100RPM high speed 1850
1997 #F7LZ8C607AB
1998 #F8LZ8C607AA low speed for 97/98 1800RPM high speed 2225
The Taurus, T-Bird, and Lincoln e-fans all use the same motor. The only difference is the blade size - 16, 16.5, 17, 17.5, and 18-inch fans and each have the same three wire configuration.
On the newer fans, you might thing you have a problem if you just apply power to each of the Black wires. On the newer fans, the low speed wire is connected to the side of the plastic housing and the second is the high-speed wire. The speed of the newer model fans is controlled 100% by the EMC. The ECM modulates the voltage to the high speed wire and this gives the e-fan its variable speeds. This give the ECM full control of the e-fan from whisper quit to full power for max-cooling. The ECM modulates the water temperature for best performance and fuel economy for the engine.
Old 05-17-2013, 01:21 AM
Clifford05's Avatar
Clifford05 Clifford05 is offline
Vehicle: 2005 Ram Pick Up
Trim Level: SLT Sport
Rep:20
Clifford05 is on a distinguished road
FlexAlite makes a kit that goes right in, made for the truck, comes with brackets and overflow and washer tank relocation kit. Also comes with a adjustable on off switch. I bought the universal kit without the brackets cause I can make them myself and I thing its around $100 cheaper! Unfortunately I have not done the job yet, will try and keep you posted! I'm doing it to basically do the same, loose the drag and free up some HP! I Can get you the part #'s if you need, lmk.
Old 05-18-2013, 02:00 PM
hemifyd's Avatar
hemifyd hemifyd is offline
Color: Charcoal Grey
hemifyd is on a distinguished road
I would like the part number and website. How much more output is the new E-Fan going to be compared to stock? I have an 2007 Ram 1500 Laramie QC w/ Hemi. I really don't want to add any Ford parts to my truck, if you know what I mean!
HEMIFYD
Old 05-18-2013, 04:44 PM
Clifford05's Avatar
Rep:20
Flexalite part #183 Fits 03-08 Ram with either 3.7, 4.7, 5.7 comes with brackets to fit factory radiator nice and also brackets to relocate the the overflow/washer tank. 3300 CFM comes with adjustable fan relay Kit goes for around $360.
Old 05-19-2013, 02:49 AM
chefred112's Avatar
Rep:656
..good luck findin a 180 tstat then...
Old 05-21-2013, 12:21 AM
Clifford05's Avatar
Rep:20
What does a 180 degree stat have to do with an electric fan? He is looking to take drag off the motor and gain some horsepower thats all he said he was looking to do. He said nothing about running cooler if that is what you are implying by using a 180 stat. If he is looking to run cooler also hypertech makes a cooler temp stat, 180 & I think a 160 degree.
