Old 05-11-2013, 05:47 PM
gmcvb gmcvb is offline
Trim Level: SLT Crew Cab 4x4
gmcvb is on a distinguished road
Default 2013 SLT honeycomb grill inserts painted
I under took a 5hr job to paint my grill inserts today (that was total time for removal, prep, prime, paint and clear coat)
Total cost was < $30
It wasn't a large or tough job by any standards but it turned out amazing after all said and done. Wish I took some pictures of the before but I did not. Here are the afters and a googled picture for comparisons.
If anyone wants any advice on how I did it just send me a message.
I plan to replace the head and tail lights to projectors in the near future and may replace the hood to the sport hood. I will be spraying the bed with line-x but light grey instead of the standard black.
Old 05-13-2013, 06:56 AM
silverrain21's Avatar
silverrain21 silverrain21 is offline
Rep:59
silverrain21 will become famous soon enough
Nice job!
Was the grill inserts easy to remove from the grill, Im planning on doing this too.
[I][CENTER]"You can only die once, make sure it's worth it"[/CENTER][/I]
Old 05-13-2013, 08:47 AM
Yes and no, once you figured out how to remove it, its a joke.
The grill itself is held in place by 4 screws and 4 plastic push clips in which I just gave it a light tug and they popped right out.
This was the toughest part of the job which isn't tough at all.
So there are 2 (what I call) air dams on the back side of the grill which funnel the air into the centre of the grill. These must be removed first before removing the inserts (I also used these to test out the paint on). The trick here is to unclip the tabs where they are the widest, I can't remember if it's top or bottom, once you remove unclip those tabs the rest is pretty easy. Hopefully you will understand when you pull off the grill. I honestly just pulled gently on the one section (farthest from the narrow tab) and it popped out.
The Inserts are held in place by tabs and gently used a screw driver to unlock them all and the inserts then just fall out.
Putting it back is a joke and takes all of 5mins.
Old 05-21-2013, 11:28 AM
Bringer's Avatar
Bringer Bringer is offline
Vehicle: 2011 Ram 1500
Bringer is on a distinguished road
Great idea for the grill! Sometimes the chrome honeycomb can look a bit flashy. It looks like you painted yours silver, and that looks pristine up against the chrome on a white truck.
Old 05-21-2013, 02:43 PM
anakin1's Avatar
anakin1 anakin1 is offline
Vehicle: 2012
Trim Level: Bighorn
Color: grey
anakin1 is on a distinguished road
100% better nice job
