05 motor swap - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
Old 05-11-2013, 07:16 PM
Nhbonecollector Nhbonecollector is offline
Vehicle: 2005 ram 1500 4x4
Trim Level: Slt
Nhbonecollector is on a distinguished road
Default 05 motor swap
I got a 05 ram 1500 4x4 with the 4.7 with almost 179000. Wanna build a new motor and was wondering if I can put a newer 4.7 in it or if I should just buy a motor from the junkyard and start building? Any advice is appreciated
Old 05-11-2013, 08:47 PM
HemiLonestar's Avatar
Rep:300
HemiLonestar is a jewel in the roughHemiLonestar is a jewel in the roughHemiLonestar is a jewel in the roughHemiLonestar is a jewel in the rough
Someone who knows a bit more about 4.7's will chime in I'm sure, but with a newer engine you might have to worry about computer compatibility. The 08+ 4.7's are quite a bit different. You might be able to rebuild your short block and go with newer heads and intake manifold if you're looking for more power.
"Big Red"
2003 Ram 1500 QC Hemi Lonestar "Big Red"
2006 Charger R/T "Little Red", 2005 Magnum R/T
(Mods list in profile)
Old 05-15-2013, 11:19 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
^yes, even though they are basically cosmetically and dimensionally the same, the newer(08+) 4.7 is very different. You would be looking at probably swapping the complete pcm and harness, all sensors, etc. along with the engine.
Sean
Old 06-15-2013, 11:25 PM
coachb66's Avatar
coachb66 coachb66 is offline
Vehicle: 2003 ram
Color: grey
coachb66 is on a distinguished road
Just my two cents, I just did a swap on my 03. I search high and low for a used engine. Almost bought a entire used truck for the parts, but every test my mechanic used. Made my search come up short. The best used engine I could get was 1800 with less then. 100,000. My enigine went out at 106,000. So It didn't make sense to me to pull the trigger. Finally found this place http://accurateengines.com/remanufac...dge/47-engine/. To be honest, I was ready to give up and move to the other side. My mechanic went back and forth checking with the company. He convinced me to go ahead a purchase this remanfactured for 1900 This still may be my last ram, but I must admit it runs like a beast! Added a better oil pump and a torque converter, it will be my sons in a couple of years. Never again will I go down this road. I thinks it worth looking into. Talking to my mechanic and Tom from accurate engines they knew everything that is wrong with the engine, I just wanted the truck to run. That It does!
Old 06-19-2013, 11:03 AM
Stampede4.7 Stampede4.7 is offline
Stampede4.7 is on a distinguished road
It's almost plug and play. You will need a tune, you only really need to run one spark plug, may need to redo the factory Y pipe, and an 08 intake adapter plates, which I have some for sale.
Stampede.
