Old 05-12-2013, 05:37 PM
Repsol69 Repsol69 is offline
Vehicle: 2013
Trim Level: Sport Crew Cab
Repsol69 is on a distinguished road
Default MPG with 22's
How much does the MPG change when you step up to a 22" wheel??
Old 05-12-2013, 10:12 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2067
Depends on more than just the wheel size. Are you going to be running the same size tire? Will the new set up weigh more than stock? Those are the two questions that will factor in to your MPG change.
I'm guessing your new set up will be heavier than stock so yes you will lose a bit of fuel economy. If you go with larger tires you'll lose even more.
Old 05-12-2013, 11:11 PM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
I didn't notice a significant change, but I don't monitor my mileage closely either.
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
