Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
tonneaucovered.com
Old 05-12-2013, 05:24 PM
02 Ram 02 Ram is offline
Vehicle: 2005 Dodge NSRT-4
Color: PX8
Rep:67
02 Ram will become famous soon enough
Default tranny flush
i wanna do a flush since i dont know what the PO did before i bought the truck. fluid is a brown color. dont think it smells burnt yet. i know dropping the pan wont get it all out. should i drop the pan or have a flush done? ive read its not a good idea to do flushes, why i dont know. one said due to not knowing what fluids will mix when a shop does the flush. any help would be greatly appreciated. TAI
2005 Dodge NSRT-4
Old 05-12-2013, 05:47 PM
Rep:2737
I talked to a local transmission guy about transmissions
he said that a particle of dirt can get caught in the valve body
He also suggested that GM vehicles should have a fluid changes quite often
I went with a complete flush & changed BOTH transmission filters at 44,000 miles on my Ram & i went with Royal Purple fluid, because i don't think i will be doing it again
Many people drop the transmission pan, pull out the valve body & clean & inspect it, change out the 2 filters & put everything back together & refill with new fluid
this process only leaves 5 quarts of the older fluid in the torque converter & the lines that go to the trans cooler & it mixes with the new fluid when you drive it
Ram 1500 SLT Quad cab, 5.7 HEMI(R) , 3.55 differential, EGR bug deflector, Bushwacker fender flares, custom soft tonneau, Line_X, DEBO Step, Mag-Hytec
2016 Ram 3.0 diesel undergoing Mods G2 tonneau, Line-X, Weathertech mats, Mag-Hytec differential cover, , customized Nfab bars, CB radio, Autonet wi-fi router
Old 05-12-2013, 06:07 PM
Color: PX8
Rep:67
so will that be OK to do if 5 quarts are left? thanks for the help BTW
2005 Dodge NSRT-4
Old 05-12-2013, 07:51 PM
Rep:2737
I can only say that i have not heard anything bad about doing it that way
just use the MOPAR compatible transmission fluid
I wouldn't put Royal Purple, AMSOIL, or another costly brand while doing it that way
you can watch this crazy guy do some of it
Old 05-12-2013, 09:31 PM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2559
Or if you do not mind the added expense, you could just drop the pan to drain the fluid, put the pan back on add the fluid of your choice. Then drive it a bit, drop the pan, change the filters etc. and then add more of the fluid of choice. Then you should have all clean fresh fluid.
Old 05-13-2013, 08:45 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:450
TransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of light
When changing your fluid and filters, any fluid that is labeled as MEETING the ATF+4 spec will work fine. Do not use fluids that are marketed as "replacement for" or "compatible with" ATF+4 (etc.). Some dealers stock Mopar ATF+4 in bulk (55 gallon drums). Last time I checked, this bulk fluid (sold by the quart) cost $5.15 list per quart. So you could check with your dealer and see if you can bring your own jug and buy some that way. The part number (for one quart of bulk fluid) is 68055894AA. Or see if you can find it cheaper at your local parts store, Wal-Mart, etc.
Changing the fluid and filters should not cause a trans to get screwed up, UNLESS one of the filters (usually, the main sump filter) is installed incorrectly. The main sump filter has a snout that plugs into a bore in the pump housing. There is a seal at this connection (which is pressed into the pump bore). If the old seal is OK (no cuts or nicks, and won't easily pop out) then leave it in and re-use it. If you replace the seal, the new seal MUST be installed into the pump bore, and tapped in flush against the casting all the way around (not cocked). Do NOT put the seal on the filter snout!! The other filter (the spin-on one) goes on like a conventional engine oil filter. Spin it in until the gasket contacts the case face, then turn it another 1/2 turn or so BY HAND until it's snug. Do NOT overtorque it, since the threaded snout on this filter is plastic and will crack if you crank it down too tight.
You can actually "flush" your own trans if you want. Here is how to do it with an RFE-series trans (545RFE / 65RFE / 66RFE / 68RFE): First, do a fluid drain and refill (and filter change) by dropping the oil pan. Then, you need to get the old oil out of the converter. When running in Park (or Neutral), oil from the converter is sent to the cooler. So you can disconnect one of the cooler lines and then pump out the converter by idling it in Park. But you don't want to run the trans dry. You also need to PLUG the other side of the cooler line (the return side) because otherwise the pump will suck air through that line. Note that the UPPER line at the trans is "to cooler" and the lower line is the return line.
On an RFE trans, you can typically run it down about 1 gallon low before the pump starts sucking air. So overfill it by 1 quart, and then do the pump-out-the-cooler-line routine until you've drained 4 quarts. That should leave you 3 quarts low. Refill and repeat.
The diesel (68RFE) converter holds just a hair under 2 gallons. Gas engine converters hold less than that. So draining two gallons out the cooler line should flush out the converter pretty well.
Old 05-13-2013, 11:57 AM
Vehicle: A Truck
Rep:2559
Interesting post and sounds like a good option for the do-it-yourselfer.
Old 05-13-2013, 01:58 PM
Color: PX8
Rep:67
thanks guys!! TransEngineer, exactly what i was looking for, thanks!!
2005 Dodge NSRT-4
Old 05-13-2013, 02:17 PM
Vehicle: N/A
Rep:450
I should also point out that if you start the engine (and run it, to set the oil level after doing the pan drain and refill), you will be blowing all the old oil (from the converter) into the sump.
So DON'T start the engine until you've got the cooler line disconnected (or ready to disconnect). Then, ALL the old oil from the converter will end up in your bucket (or, if you're like me, probably on the driveway!) instead of mixed into the pan. It normally takes about 7 quarts to refill an RFE trans after a pan drop, so I would throw in 8 quarts and then start it up and pump a gallon out the cooler line. Then shut it off, add another gallon of fresh oil, and pump out another gallon. Then shut it off, reconnect the cooler line, add 2-3 quarts, then start it up again and set the final level.
Old 05-13-2013, 02:50 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
LOL
And they say engineer's don't have a sense of humor...
Sean
