Old 05-26-2013, 09:04 PM
97dodgeram 97dodgeram is offline
Vehicle: 1997 dodge ram 1500
Color: blue/silver
97dodgeram is on a distinguished road
Default help
So i took my 97 dodge mudding this weekend and went through a mud bog it was pretty deep i made it through nothing weird was going on i shut the truck off and when i try to start it just makes one click took the plugs out to see what would happend and still just clicks once tried hitting the starter with a hammer. Did starter just go out or am i in deeper problems?
Old 05-26-2013, 09:30 PM
DarthRam's Avatar
DarthRam DarthRam is offline
Rep:1543
Did you check the battery? Have the battery tested before you start replacing expensive parts.
Old 05-26-2013, 09:38 PM
Color: blue/silver
yeah the battery is fine
Old 05-27-2013, 04:19 AM
Vehicle: 2012 Ram Express
Rep:63
Verify battery is good, I just watched a hard headed friend change a starter when all he needed was a battery.. I tried not to laugh at him because it took him two days to do the starter, then had to turn around and buy a battery.. like I told him to from the start.. Check all your battery cables/connections. Clean everything if you see any corrosion build up. You possibly could have damaged your starter wire. Check or swap out the solenoid next. Also poke through your fuse boxes, you never know with todays cars.
Old 05-27-2013, 10:28 AM
Color: blue/silver
i know battery is good. it looked like a wire might have had some damage going to the starter going to really dig into it today will let u know what i find
Old 05-28-2013, 12:06 PM
98rumblebee's Avatar
98rumblebee 98rumblebee is offline
Vehicle: 1998 Dodge Ram 1500
Color: Yellow + Black
98rumblebee is on a distinguished road
Same thing happened to my buddy's Cummins one time, it turned out he just got a fuse wet and shorted it. before you replace anything, just go through and check out all your electrical stuff. Also, I would try throwing a jump on it if you haven't already, just to make sure...
Put a good dip in
