Old 02-16-2011, 07:13 PM
B Rue48's Avatar
B Rue48 B Rue48 is offline
Vehicle: 1998 Ram Ex. Cab 1500 5.9
Trim Level: SLT Laramie
B Rue48 is on a distinguished road
Default I got an iffy problem...
My truck idles funny. It'll idle for like a min or two then starts shaking and sounding like its choking on something. Today I took a note that it sounds like it is being fuel starved. I started it and popped the hood, and just listened. When it started to act up, it sounded like it was sucking in more air as it got worse. The kicker to this is that when its dropped in gear it runs perfectly fine. Any ideas? All feedback is greatly appreciated. Thanks!!
Eatin Chevy, SHITTIN Chevy. DODGE RAM
Old 02-17-2011, 08:21 AM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
maybe your fuel pressure is dropping at idle, i read a thread on here where a guys fuel pump was going bad and was at 4 psi all the time. i thaught when a fuel pump was bad it just didnt run at all but i was wrong. maybe have your fuel rail pressure checked out, thats one canditate. i think its supposed to be around 33 psi, something like that.
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 02-17-2011, 06:03 PM
B Rue48's Avatar
Thanks man I'll check that out!
Old 02-17-2011, 07:23 PM
RamTech RamTech is online now
Rep:1909
Running at 4 psi? Sure, if it's a carbuerated engine. Fuel pressure should be 44-59 psi.
Old 02-18-2011, 07:44 AM
98redbull2's Avatar
Rep:52
o damn i was still a little low lol yea idk the guy said his truck was runnin on 4 psi, it was knockin and pingin under load and the check engine light would flash so that would prolly do er lol.
Old 02-23-2011, 11:50 PM
livinlifes2short livinlifes2short is offline
Vehicle: 97 Dodge Ram Sport
livinlifes2short is on a distinguished road
Hey guys new here and did a search found our post, I am having the same problem, i just replaced my fuel pump a month ago and this was happening before and after, sounds like a have a dang turbo makes a loud sucking noise from the throttle body area and idle drops some times it will pick back up or I have to give it gas a few times for it to fix its self, or like he said put it in gear. Makes me think that its the IAC valve is there any way to test this without a computer? Or any other good thoughts?? Thanks 97 5.9 ram sport
Old 02-26-2011, 09:29 AM
magnumv8 magnumv8 is offline
Vehicle: 1999 Dodge Ram 1500 5.9 4x4
magnumv8 is on a distinguished road
I am having the exact problem. it started sucking air bad after my battery died and i replaced it with a new one. started running rough and wanted to die out in park or nuetral. after i shut it down and turn it back on it ran fine for a few days, now it will not start and just cranks, and i can smell fuel afterwards any help would be very much ppreciated
Last edited by magnumv8; 02-26-2011 at 12:41 PM. Reason: adding additional information
Old 02-28-2011, 01:19 PM
I go out and try to start the truck every morning and it did start for me today. but it started and blew out some smoke and then it idles i would say around 600 to 800 rpm. but there is a tick tick tick tick coming from the left side of my enginge. athe truck has 186000 miles on it but the top end was rebuild. this all started when i took the alternator off and put it back on and replaced the battery. i dont want to drive it like this if it will do more harm.
Old 03-04-2011, 07:05 PM
sdram03's Avatar
sdram03 sdram03 is offline
Vehicle: 2014 RAM 3500 Big Horn
Color: Maximum Steel
Rep:52
sdram03 will become famous soon enough
i was thinking the same thing... IAC. the sucking problem can be the IAC adjusting, letting in more air to adjust the idle. and then when in gear, there's a load on the engine and ecm may have already adjusted with more fuel. if there is too much carbon around the IAC, that can cause issues too. if the AFR requires more air (according to what O2 reading during closed-loop), ecm will try adjust the IAC to fix it. well, too much carbon may not let the proper air get thru and now the IAC, O2, ECM are all fighting to get the engine to run right. oh, and include MAP sensor in there too. i'd remove the IAC and make sure it's nice n clean and the ports associated with it are spotless. i had a plymouth that was PICKY!!!! did a lot of short driving and had to clean the IAC almost every other oil change. otherwise, it would Idle like CRAP. and don't even think about turning on the A/C. the extra load was enough to put it over the edge and kill the engine.
if you're gonna go, go with a smile!
2014 RAM 3500 Big Horn CTD CC 4wd in Max Steel
Old 05-12-2013, 09:07 PM
Justin69 Justin69 is offline
Vehicle: 1999 dodge ram 360
Trim Level: 2 Ginn
Justin69 is on a distinguished road
My 99 douse the same thing can't figure it out if u figure it out email me justinhillyer@gmail.com
Transmission Problem 07 Hemi 07Ram 5.7L V8 Specific Topics 14 03-14-2013 06:45 PM
Please Help! Engine Problem mowery33 5.9L V8 Specific Topics 6 01-28-2011 09:49 AM
First Dodge - First Ram - First Post - First Problem koolaidzx2 Newbie Checkin! 11 01-17-2011 12:10 AM
Door Ajar Light & Power Windows Problem. scottdutton Electrical 1 12-05-2010 04:54 PM
Yet another HID problem griffin407c Custom Dodge Ram Interior and Exterior Lighting 10 10-27-2009 04:37 PM
