United Radio
Old 05-13-2013, 07:07 PM
cmpx3 cmpx3 is offline
cmpx3 is on a distinguished road
Default longtube header vs. O2 sensor
hoping I can get some advise from someone who has already fought CEL codes after long tube header install. I have an 07 Ram with 5.7 hemi in it, and Superchips 93 tune installed. I installed some obx-r s.s. longtube headers and magnaflow high flow cats. I have the rear o2 sensor problem fixed with the non-fouler trick. I had to install wiring extensions from summit on the 2 rear sensors and the pass. front. The one code I cant get rid of is PO133 bank 1 sensor 1. Unless I'm wrong it is the passenger front. I have no leaks and from what I can tell the wiring is fine. I have swapped sensors front to rear (bosch). All sensors are new. I have reset the pcm. Took off the extension on the front pass. and got it to reach and it actually threw 3 codes. Put the extension back on and back to po133. I swapped the extensions on the pass. side front to rear today but haven't driven it yet. None of these things have helped. Thought about trying a different brand sensor ( didn't know bosch had a bad rep till after I bought and installed them). Hoping someone has a idea for me. Whats throwing me is the code is only on one side of the front not both. Please help. thanks
Old 05-13-2013, 09:01 PM
after searching the net I'm getting conflicting answers on which side of the cats is bank 1 and bank 2. Anyone sure on this?
Old 05-13-2013, 09:31 PM
Raminator5280's Avatar
Raminator5280 Raminator5280 is offline
Vehicle: 2007 Dodge Ram
Trim Level: SLT Bighorn
Rep:56
Raminator5280 will become famous soon enough
I have been fighting that code for 4 months. I had a custom tune done to change the timing it takes for the front sensor to respond. About 3 months after the tune it came back...I deleted the light and hasn't come back yet. I would still say that longtube headers are worth the trouble though.
DiabloSport Trinity w/CMR tune, K&N FIPK, 87mm ported TB, Dynatech LT Headers, Magnaflow cats, ypipe, & muffler, Jetstream scoop, diy ram air, push start
Old 05-13-2013, 10:18 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
bank 1 = drivers side
bank 2 = passenger side
Old 05-13-2013, 11:36 PM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 2007 1500 Mega Cab 4X4 3.73
Color: Inferno Red
Rep:185
namretsud has a spectacular aura aboutnamretsud has a spectacular aura about
NTK is the oem sensor of choice. I have seen Bosche as a problem O2 sensor on other mopar models.
Old 05-14-2013, 01:11 AM
Gecko's Avatar
Gecko Gecko is online now
Vehicle: 2004 Quad Cab
Trim Level: SLT 4x4
Rep:214
Gecko has a spectacular aura aboutGecko has a spectacular aura aboutGecko has a spectacular aura about
You could just get a custom tune to turn the rear sensors off. That's what I did...
Supercharged, cammed, other things too!
Old 05-14-2013, 02:46 PM
Im not having any rear sensor issues just front drivers side. Called the dealer this morning to confiem bank 1 was drivers side. This is the only sensor without a 24" casper extension on the wires. Anyone think that might have something to do with it? As posted above , acustom tune crossed my mind. Would I have to ditch the superchips and go with an sct or someone like lthat to get a custom tune? I ordered a ngt o2 sensor last night to try tbat as well. Thanjs for all the responses so far
Old 05-14-2013, 03:27 PM
Rep:56
I see a lot of people suggesting tuning the rears out. But I guess I don't understand why turning off the rears will prevent a p0133 slow o2 repsonse bank 1 sensor 1. Is the slow respomse because of the extra distance the front o2 was moved back?
Old 05-14-2013, 03:28 PM
Got to thinking about leaks. If I have one I damn sure cant hear it or feel it. If i had a small leak( not detctable by the ear) would it throw the po133 code from that far away from the sensor. With the long tube header its pretty far. Thanks
Old 05-14-2013, 03:30 PM
Rep:56
Ill be curious to see how the new o2 sensor works for you as I am having the same problem. But I have the custom tune and brand new o2s.
