Old 05-13-2013, 07:37 PM
Solomon0619 Solomon0619 is offline
Vehicle: 2010 dodge ram
Trim Level: Slt
Solomon0619 is on a distinguished road
Default Tires?
I have a 2010 1500 with a 2.5 level kit and stock 17" rims. I am going to get new rims and tires either a 17 or 18 rim and am wondering if 35s will fit without rubbing issues with just the level kit?
Old 05-13-2013, 08:02 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
yours rims need to be a 0 or negative offset and you'll be golden!
Old 05-13-2013, 09:30 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2111
Yup, exactly what gonefishin776 said ^^^
Old 05-15-2013, 10:09 AM
Trim Level: Slt
So if I go with a 18 x 10 with -24 offset and 35" mickeys I'll have no rubbing? Or would I be better with a 17x9 -12 offset? Just have heard a couple people say they had issues with rubbing when turning and want to make sure I'm good. Thanks for the help guys.
Old 05-15-2013, 10:11 AM
Rep:1900
depends on the stance you want...you should be fine with both.
the 18x10 -24mm will stick out a good bit further than a 17x9 with -12mm
but both will look good in my opinion.
Old 05-15-2013, 11:45 AM
Rep:2111
With the 18x10 -24 offset you will rub on the back of you inner fender (where they buldge out) near full lock. The 17x9-12 offset will probably do the same but not as bad. It can easily be fixed with a little bit of trimming though. Mine 20x9 -12 offset with 35" Toyo MT's do the same thing but it is very minimal. Here's a link to my thread that talks about the rubbing a bit with a few pictures of where the problem is:
http://www.ramforumz.com/showthread.php?t=141365
If you want absolutely no rub, stick to a 9" wide wheel with a 0 offset.
Old 05-15-2013, 12:24 PM
Trim Level: Slt
Thanks for the link! Nice truck! After reading and seeing it I think I will go with the 20s and -12 offset 35" mickeys. I noticed you had the rear coil spacers on yours, will not having them on mine create any issues? And you just had to trim the plastic fender correct?
Old 05-15-2013, 12:26 PM
Trim Level: Slt
One more thing so a 20 x 9 with 0 offset and 35s will not rub anywhere? Sorry for all the questions just wanna know everything I can before going through with a purchase.
Old 05-15-2013, 12:37 PM
Rep:2111
Thanks!
I have rear coil spacers just to give me a little bit of rake. With my 2.5" leveling kit the truck was too level IMO and looked a little nose high at times. The 0.75" rear coil spacer gave it the stance I wanted. You don't need them to clear the tires at all.
So far all I have done is taken off the plastic trim piece at the back of the fenders. This helped the rubbing issue a little bit. They still do rub slightly but like I said it's only near fully lock and not enough to force me to fix it ASAP. I'll probably get around to it this weekend.
Correct, with the 20x9 0 offset you shouldn't rub at all. Mine only rub because they are a -12 offset which pushes the wheel out 0.5" further therefore when I turn it is closer to the inner fender.
Old 05-15-2013, 12:55 PM
MangoTangoMofo's Avatar
MangoTangoMofo MangoTangoMofo is offline
Vehicle: 2010 1500 Sport 5.7L Hemi
Trim Level: Sport Quad Cab
Color: Mango Tango
Rep:98
MangoTangoMofo will become famous soon enough
Thanks!
^^^ Everything that he wrote is correct.
I have 35” Toyo MT’s on 17” XD Cranks with 0 offset and a 2.5” Rough Country levelling kit with a 1.75” rear spacer. I have absolutely no rubbing… just to confirm what you’re reading here.
If you’re curious here is a link to my thread with at little write up:
http://ramforumz.com/showthread.php?t=139401
5x11x22 Magnaflow with a resonator delete // Rough Country 2.5F&1.75R level kit // 17 XD Cranks // 35x12.5x17 Toyo MT's // Air Lift 1000 // Armor Thane bed liner // Century Ultra Sport Canopy // Yakima Roof Rack // Mopar side steps // Custom Browning Mudflaps
