Old 05-16-2013, 09:24 AM
Solomon0619 Solomon0619 is offline
Vehicle: 2010 dodge ram
Trim Level: Slt
Solomon0619 is on a distinguished road
Okay so the rims I would like to get only come in 20x9 with a 1 or 14 offset. Is there any type of spacer I can use to make these work?
Old 05-16-2013, 12:02 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2036
The 20x9 +1 offset will work No spacer needed.
Old 05-17-2013, 01:33 PM
MangoTangoMofo's Avatar
MangoTangoMofo MangoTangoMofo is offline
Vehicle: 2010 1500 Sport 5.7L Hemi
Trim Level: Sport Quad Cab
Color: Mango Tango
Rep:98
MangoTangoMofo will become famous soon enough
Yepp, you should be good with the +1!
Offset is measured in Millimeters (opposed to back spacing which is referred to in inches) so the difference between 0 and +1 is only 1mm so just shy of 1/16 of an inch.
If you were to get the +14 you would move the rim IN 14mm or just over 1/2 an inch toward your control arm and it would rub... get it?
Just in case you haven't seen this excellent post with a link that explains backspacing/offset have a read:
http://www.ramforumz.com/showthread.php?t=86816
5x11x22 Magnaflow with a resonator delete // Rough Country 2.5F&1.75R level kit // 17 XD Cranks // 35x12.5x17 Toyo MT's // Air Lift 1000 // Armor Thane bed liner // Century Ultra Sport Canopy // Yakima Roof Rack // Mopar side steps // Custom Browning Mudflaps
