Old 05-13-2013, 08:06 PM
AzDusty's Avatar
AzDusty AzDusty is offline
Trim Level: Laramie Longhorn
Color: Deep Cherry Pearl/Gold Two-Tone
Rep:37
AzDusty is on a distinguished road
Default Tons of questions so little time (ok 6-7 months)
Ok as I said in my newbie introduction, I been bouncing between the Ram 1500 and the Tundra (both will be a 2014). I really liked what I saw on the Ram the other day as opposed to what I see in the "ALL NEW" Toyota Tundra (as long as you don't look under the hood or under the body or in the interior).
So here are some of my wants.
1. Tonneau cover (what I don't know is do I want a fold up or a flip up.
2. Spray in bedliner
Ok so here is my questions or deliberation points. As far as the Tonneau cover goes I more than likely will not use the bed much other than to load the camping gear or groceries. I dont envision me hauling 15 ft palm trees (although it could happen) so why a fold-up over a flip up?
Do I factory install this or try to find a better (less than 100 bucks I assume) deal somewhere else? I don't necessarily want to be the installer either although I hear these things get easier each year to install correctly the first time.
I assume that the flip up is more secure but from what I have been seeing the fold-up are pretty dang secure too (just wouldnt recommend dancing on one)
Spray in bedliner, basically there are two brands if I am correct Line-X and Rhino, from what I have been reading the Line-X (no offense to anyone) seems to be getting better reviews. So do I go with Line-X and spend identical cost or go with the factory? I suppose the biggest benefit on the factory is that it is there when you pick up the truck but does it also become part of the truck warranty because it was installed by Ram? (Same question with the Tonneau cover)?
Ok one post of I would say probably 50 or so more questions....
Thanks in advance (in case I forget)
RAM 1500 4x4 Laramie Longhorn
Old 05-15-2013, 06:10 AM
Kcbigbadram's Avatar
Vehicle: 2014 1500
Trim Level: limited
Rep:497
You can't go wrong with either line-x or rhino I don't think. But since you said you don plan on using the bed that much, I personally would save the money and go with rhino. Around me rhino is about 100-150 cheaper than line-x and I've never had a problem with either one. But they both carry lifetime warranties, so if it does mess up they'll fix it
