Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 05-14-2013, 02:46 AM
BobcatDude BobcatDude is offline
Vehicle: 2004 Ram 1500
Color: Blue
BobcatDude is on a distinguished road
Default headlamp not burnt out but won't light up???
Passanger side low beam out, or wont turn on? but not burnt out? lamp out light on dash?
please help!!!
done so far, check all fuses, disconnect battery, listen to ding ding ding, crying, lol
any help would be greatly appreciated! thanks in advance
2004 Ram 1500, Qcab, 4x4, hemi, auto
Old 05-14-2013, 08:14 AM
Chris65 Chris65 is offline
Vehicle: 2007 Dodge Ram
Color: silver
Rep:45
Chris65 is on a distinguished road
Turn your headlights on-close the door because of ding ding- and unplug the headlight.
Check with the multi meter if you have power. If not, go to your bank, get $650.00 out, make a trip to the frienly dodge dealer and buy a new tipm. Disconnect battery and change the tipm
Problem solved.
Everything else is waste of time and miney, because at the end u need a tipm anyway.
Old 05-14-2013, 11:53 AM
I push the skinny pedal
Rep:3308
^^ this is most likely. OR you can do what I did and just trigger the passenger low-beam with a relay from the driver side and live with knowing the TIPM p/s low circuit is fried.
Kurtis
Old 05-14-2013, 03:27 PM
Color: silver
Rep:45
The question is, how long that lasts and more burns out. Either way you will end up with a tipm.
Old 05-14-2013, 10:30 PM
Color: Blue
Great where about is this TIPM located?
Old 05-14-2013, 10:32 PM
Arth's Avatar
Arth Arth is offline
Color: Deep Cherry Red Crystal Pearlcoat
Rep:2035
Hang on a sec. You are saying that the lamp out is going off on your dash... but the bulb is not blown? Have you pulled out a mutlimeter and check to see if the voltage is even going to the plug connecting to the headlight?
Sure would suck if it was as simple as a ground or something gone wrong.
Chrome... in moderation.
Old 05-14-2013, 10:39 PM
Color: Blue
Problem solved.
also i have read that the 06 and up recover the TIPM from a tuner reflash? would flashing with a bully dog or Diablo reset this?
Old 05-14-2013, 10:46 PM
Color: Blue
LAMP OUT light blinks and dings when I start it up, then just stays on, no power at plug muti meter and test light, even jumped ground to -battery
Old 05-14-2013, 10:49 PM
Arth's Avatar
Rep:2035
Yikes. Me personally I would try to find the wire and follow it back but that is me. As said above it may be a TIPM.
Old 05-14-2013, 11:11 PM
Rep:3308
Occasionally, but in most cases a toasted circuit is done because it's a physical issue not a programming one.
Kurtis
