Old 05-14-2013, 12:48 PM
Gen1Ram Gen1Ram is offline
Vehicle: 1994 Dodge Ram 2500HD pickup
Color: Blue
Rep:17
Gen1Ram is on a distinguished road
Default Intake Manifold Gasket
I want to change the intake manifold gasket on my 1994 2500 5.9
How big of a deal is this and does anyone have any advice on procedure, pitfalls to avoid?
Old 05-15-2013, 06:43 PM
Tricky69 Tricky69 is offline
Vehicle: 1999 ram 1500;1999 ram 2500V10
Color: White///Black
Tricky69 is on a distinguished road
change the plenum gasket also
Old 05-15-2013, 06:44 PM
not very hard once everything is out of the way. took me about 6 hrs from start to finish
Old 05-15-2013, 10:31 PM
hardcableman's Avatar
hardcableman hardcableman is offline
Vehicle: 2001 Dodge Ram 2500
Trim Level: standard
hardcableman is on a distinguished road
go on you tube type in plenum gasket dodge n find one n watch easy as watch and do
Old 05-22-2013, 01:49 PM
Color: Blue
Rep:17
Thanks guys.
found this http://youtu.be/R-0Iyr9hT3A
Old 05-22-2013, 02:36 PM
Color: Blue
Rep:17
Default Replacing the plenum gasket
And here is another related instructional
http://goo.gl/6OIpF
Old 05-23-2013, 12:06 AM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Might as well get the Hughes Performance Plenum kit. Comes with all gaskets, new hose to manifold from block, thermostat, new bolts, etc.
It's not a bad job, but can be a little daunting the first time. I can have it off in about an hour now.
Basically just remove intake, alternator, ac compressor, accessory bracket, radiator hose, fuel injector plugs, throttle body linkages, and vacuum lines.
