Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 05-14-2013, 08:49 PM
hpyman123 hpyman123 is offline
Vehicle: 2001 Ram 2500 Diesel 4x4
Color: Driftwood
hpyman123 is on a distinguished road
Default ABS and Brake light on dash
Well these 2 lights came on. I have changed the rear ABS speed sensor with no luck. I checked the brakes for adjustment and found a broken retainer spring. It moved around and chewed up the front shoe and the drum a little so I bought hardware kits, new drums and shoes and rebuilt both of the rear brake systems. Still have the lights on the dash. Have scanned the truck with my scanner which says it checks ABS codes and it says there are none. The brake fluid level is OK so I am at a loss for an answer.
Old 05-17-2013, 11:51 PM
Howells's Avatar
Howells Howells is offline
Vehicle: 1999 dodge ram sport 5.9l
Trim Level: sport 4x4
Rep:19
Howells is on a distinguished road
Those are the 2 main things that could cause those lights to be on. If you speedo is working the rear sensor should be working. Does your truck have 4 wheel abs. I don't know what year they started but it's possible one of the front wheel speed sensors are bad. Or the fluid sensor in the master is bad. That would possibly explain no dtcs. Just a thought. Good luck
Old 05-20-2013, 11:19 AM
Color: Driftwood
The truck has only RWAL. I may just have to break down adn go to the dealer and have them scan the ABS. Even though my scanner says it will do it, it wouldn't be the first time it was wrong.
Old 09-21-2013, 06:58 PM
dirtydiesel51 dirtydiesel51 is offline
Vehicle: 2000 Dodge Ram
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
dirtydiesel51 is on a distinguished road
Try switching out the rear wheel abs sensor on top of the driveshaft. Its an easy fix and it worked for me. Is your speedo working fully?
Old 09-21-2013, 07:42 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I'd jack up the front and check the hub bearings and clean the sensors. An '01 SHOULD have 4 w ABS, but that's not a definite.
If you have in fact ruled out the rear brakes. If the rear shoes needed hardware be sure to check the wheel cylinders. If one has a slight leak that'll throw the ABS light also because of the pressure differential.
Old 11-21-2013, 12:12 AM
capnfishook capnfishook is offline
Vehicle: 2001 Ram 2500 4X4
Color: Garnet
Rep:20
capnfishook is on a distinguished road
Default ABS and Brake Light On
My 2001 Ram 2500 4x4 has the same problem. The lights came on sporadically at first, but stay on full time now. The scanner pointed to the right front wheel speed sensor. I replaced it, but no change. The next step is to inspect the toner ring, but that requires pulling the front axle(!) which is something I don't want to do. What else can be done?
